mark handler
Ramp
3.) The small ramp does require side curbing (yes/no)?
Yes but can be a part of the railing
4.) If the handrails are installed on the lower ramp then the handrails are required to extend in to the parking lot with extensions (yes/no)?
yes, but can be rotated 90 degress (perpendicular to ramp) for existing ramps...
Stairs (which are currently not part of the project)
3.) does the 2010 ADA require the stairs have contrasting lines at the edge?
Required in ANSI 117.1 Advised in ADAAG
4.) The handrails are wrong for more than just the ADA, but, my question is since church owned because it's use is for income to a business, the church's exemption from requirement is removed, correct (yes/no)
Is the daycare run by the Church? If yes, exempt from ADA but not ANSI 117.1 or state access codes.
If no, Not exempt from ADA
