Re: RAMP THAT'S NOT A RAMP
The IBC is not a federal law wannabe so get off that shtick. It's a building code not civil rights legislation.
Yes group A buildings are exempt from vertical accessibility except as specified in 1108.
Since worship areas are not required to provide vertical accessibility by 1108, none need be provided.
The ICC and Access Board tried to jamb the IBC through as ADAAG. Fortunately they failed.
All the effort was on changing ADAAG to match A117.1 and Chapter 11. None was on changing the building code. Your tax dollars at work.
Almost. The IBC indicates all buildings are subject to Chapter 11 and then lists the areas where non-applicability exists. As you note, it is not federal law. It is stand alone. The IBC does not have first amendment issues with its application or subjective feelings about fraternal organizations like the members of congress espouse.Gene Boecker said:brudgers said:"Performance area" is directly from ADAAG. By definition anything in ADA does not apply to places of worship.
If the IBC was intended to apply to areas used for worship, it would so state...of course it doesn't since doing so would conflict with the scheme for turning A117.1 and the IBC into ADA law.
