steveray
All of them...Do you enforce any codes you don't agree with?
I am not the BCO (AHJ) anywhere, just an inspector, and I don't know if the BCO is requiring it. I just never saw one in my 18 years of an inspector, and I do most of the commercial inspections here.Then you never looked close enough. This was something that I discussed with PA L&I back in the mid 2000's because it was in question in some municipalities. The director at the time, I think it was a John was adamant that resurfacing & resealing and relining did, in fact, require a permit and the L&I required permits and inspections on all of the properties they were in charge of in opt-out communities and state-owned buildings. As a matter of fact, during the conversation, I remember him telling me that Penn State main campus was under a permit for a major parking lot resurfacing. It was at that point that we made sure that all resealing, resurfacing projects were permitted in all of the municipalities we worked in.
It is required, it has been required. Why you don't enforce it is a question you have to ask yourself.
Restriping a parking lot to be the exactly the same striping pattern as it was before is notSo if we did make them get a permit for resurfacing a parking lot I still don't know how we could make them paint new lines for an accessible parking spaces. For an existing building we would go to the 2018 IEBC:
SECTION 305
ACCESSIBILITY FOR EXISTING BUILDINGS
305.1 Scope. The provisions of Sections 305.1 through 305.9
apply to maintenance, change of occupancy, additions and
alterations to existing buildings, including those identified as
historic buildings.
I would think a parking lot resurface would be a repair. As you can see the above section there is nothing about accessibility for repairs.
If you think it is not a repair but an alteration to a primary function:
305.7 Alterations affecting an area containing a primary
function. Where an alteration affects the accessibility to, or
contains an area of primary function, the route to the primary
function area shall be accessible. The accessible route to the
primary function area shall include toilet facilities and drinking
fountains serving the area of primary function.
1. The costs of providing the accessible route are not
required to exceed 20 percent of the costs of the
alterations affecting the area of primary function.
If you think a parking lot is a primary function, they could choose to spend the 20% on something else than an accessible parking space.
Rick is kind of right here, not a great code path....I would use this section to "make it right" I think:So if we did make them get a permit for resurfacing a parking lot I still don't know how we could make them paint new lines for an accessible parking spaces. For an existing building we would go to the 2018 IEBC:
SECTION 305
historic buildings.
Jeff...I know you know PA stuff, and I do not presume to, but our code requires us to use the IEBC for existing:Stop looking to the IEBC for reasons not to enforce the codes and standards as written.
Not sure I agree with that statement given the definition of a structure...A parking lot is not a structure.
And in case anyone wants to point out that I am using an IBC definition for an existing structure...Not sure I agree with that statement given the definition of a structure...
2021 IBC [A] STRUCTURE. That which is built or constructed.
So if you build a pile of dirt, it is a structure?And in case anyone wants to point out that I am using an IBC definition for an existing structure...
2021 IEBC 201.3 Terms Defined in Other Codes
Where terms are not defined in this code and are defined in the other International Codes, such terms shall have the meanings ascribed to them in those codes.
Don't shoot the messenger. I just gave you what the code says.So if you build a pile of dirt, it is a structure?
If you build a lake it would be a structure?
No not until they actually do something to the building.would you make them put in an accessible parking space?
Another fine excuse to not do your job to the best of your ability. Inspect to a lesser standard and don't require things so you don't lose your contract. Awesome!Our inspection company already lost some townships because they thought we were too strict. I have seen lots of things while driving around that don't look kosher. I report it to the BCO. But from there I don't pay attention to what happens.
