    Dismiss Notice
Residential concrete slab help.
Discussion in 'Residential Foundation Codes' started by Garrett Foster, Jun 8, 2019.
  1. Garrett Foster
    Garrett Foster Garrett
    Jun 8, 2019
    30
    3
    Right now I'm having issues with a 2 week old slab for my house. The GC says all the cracks are acceptable and happen to every slab. Basically I'm looking for any codes for residential concrete.
    Any help would be greatly appreciated?
  2. fatboy
    fatboy Administrator
    Oct 17, 2009
    5,860
    610
    Non-structural residential slabs are not covered under the Residential Code. There should have been stress joints cut or tooled into the slab to direct/hide any cracking. Yes, slabs move, but you can attempt to control the movement. Sorry if you are stuck with poor workmanship, that sucks.
  3. Garrett Foster
    Jun 8, 2019
    30
    3
    Yeah. I wish I could post pictures. 7 days after the pour cracks were all over, rebar ties above the concrete, and massive amounts of rock showing when they pulled forms off.
  4. ICE
    ICE Sawhorse
    8,643
    1,000
    Pictures would help. How wide are the cracks? Was there an inspection prior to placing the concrete? Was the soil compacted? Was there just dirt under the slab or was there gravel? Was the concrete deposited directly out of the truck or was it pumped? How about reinforcement...what is it?
  5. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    10,482
    827
    Is there fracking going on nearby?
    Rather than removal of the slab, I would recommend Xypex Crystalline waterproofing technology
    https://www.xypex.com/
  6. Garrett Foster
    Jun 8, 2019
    30
    3
    Some cracks about an 1/8" some are smaller. It has 3/8" rebar, fill dirt and some sand. I wasnt there for the pad or slab pour so idk about compacting. The concrete was poured directly from the truck. However they had to wait 45 minutes + between trucks.
  7. Garrett Foster
    Jun 8, 2019
    30
    3
    No fracking.
  8. north star
    north star Sawhorse
    Oct 19, 2009
    3,820
    270
    Garrett, ...do you have a signed contract with
    whomever constructed the foundation, before
    the concrete was placed ?.......Is there a jurisdiction
    involved in this project ?......Permits ?......Inspections ?
  9. Garrett Foster
    Jun 8, 2019
    30
    3
    Is there a way to add pictures here?
  10. mark handler
    Oct 25, 2009
    10,482
    827
    Still recommend:
    Xypex Repair for Cracks & Faulty Construction Joints
    Repair Procedures
    https://www.xypex.com/products/installations/repairs/cracks-faulty-construction-joints
  11. Garrett Foster
    Jun 8, 2019
    30
    3
    We have a contract that says they will do everything to code. We are out of city limits so there are no permits.
  12. Garrett Foster
    Jun 8, 2019
    30
    3
  13. mark handler
    Oct 25, 2009
    10,482
    827
    Should be done professionally, but some homeowners maybe able to do it
  14. Garrett Foster
    Jun 8, 2019
    30
    3
    I'll check it out. I already had a quote for something similar in the $7000 range
  15. north star
    north star Sawhorse
    Oct 19, 2009
    3,820
    270
    What Code ?.......Inspected by anyone before the
  16. Garrett Foster
    Jun 8, 2019
    30
    3
    As far as I know they built the pad up 4'. Then poured footing Then set forms and plumbing then poured concrete.
  17. north star
    north star Sawhorse
    Oct 19, 2009
    3,820
    270
    Does your contract have provisions for unacceptable
    work ?.......Has anyone with professional experience
    & credentials inspected & evaluated this foundation ?
    Did anyone with plumbing experience test & inspect
    the plumbing system before concrete was placed ?
    So, no one actually inspected the work before placing
    the concrete ?........What Code was supposed to be
    followed ?.....Do you know of, or have a really good
    and experienced construction attorney ?
    jar546 likes this.
  18. cda
    cda Sawhorse
    Oct 19, 2009
    17,107
    1,137
    Become a Sawhorse $ 35 which helps keep the forum going and cheaper than a engineer !!!
    Or make pictures a link and post the link
    I think some use Flickr
  19. Garrett Foster
    Jun 8, 2019
    30
    3
    It's outside city limits so I have no idea what code has to be followed. The slab has been inspected and found faulty due to moisture issues and will require resurfacing and moisture protection. There was no inspection prior to concrete other than the concrete guy. They cut control joints over a week after the pour. Which I said I didnt want.
  20. cda
    cda Sawhorse
    Oct 19, 2009
    17,107
    1,137
Share This Page
