Shelfs above aceessible water closet
mark handler said:
Some people use the rear grabbar to stand, or transfer, leaning against the wall, a cabinet could interfere with that.If you want to continue to have lawsuits; continue to poorly design and enforce the codes and standards.
Why do we continue to have lawsuits. ...?
People continue to find any way to skirt the intent of the accessibility codes and standards
My suggestion is to place the cabinet five feet above the toilet
My suggestion is to cease with the threats of lawsuits and put that effort (money) into changing the laws.
The intent is to increase accessibility, not reduce it by installing items that do not belong in areas intended to remain clear. These are not threats. The lawsuits will come if you do not design, build and inspect correctly.
Webster would disagree, your making a threat step up and own it. If it's reviewed and inspected to code that is correct. If you know of a code section that says other wise cite it.
Calm down, you are going to blow a gasket
The intent of all accessibility codes and laws is to provide the greatest access to the greatest number of people. No two disabilities are the same.
If you read the ADA, not the standards, it, not Webster, defines the intent of the ADA.
Excellent response MH. The answer is in the intent, though code and the ADA contain both prescriptive and general directives.
It is where it is silent and the generals that hang many while providing defense to a few as MG and CALDAG use as defenseable justification for not providing more than the minimum prescriptively required and no more.
If "best practice" and the "right thing" is the "intent" of the ADA, who then is the judge of whether it is or isn't? ADA alludes to the designer, assuming he/she can defend their decision.
604.3.3 CLEARANCE OVERLAP: Shelfs are listed as one of the things that can be in the clearance space. I would think a shelf coming out two feet or more 12" above the grab bars or in the space next to it would be a problem what the code allows it. I don't know why the code would allow a shelf but not a counter or cabnet?
mark handler said:
Calm down, you are going to blow a gasketThe intent of all accessibility codes and laws is to provide the greatest access to the greatest number of people. No two disabilities are the same.
If you can read where in the ADA standard does it define these threats of lawsuits that you make? Cite a code section or a section from the ADA standard instead of just blowing more smoke.
kilitact
Since you keep harping on lawsuits:
ADA Enforcement
Through lawsuits and settlement agreements, the Department of Justice has achieved greater access for individuals with disabilities in hundreds of cases. Under general rules governing lawsuits brought by the Federal government, the Department of Justice may not sue a party unless negotiations to settle the dispute have failed.
The Department of Justice may file lawsuits in federal court to enforce the ADA, and courts may order compensatory damages and back pay to remedy discrimination if the Department prevails. Under title III, the Department of Justice may also obtain civil penalties of up to $55,000 for the first violation and $110,000 for any subsequent violation.
http://www.ada.gov/doj_responsibilities.htm
Private individuals may bring lawsuits in which they can obtain court orders to stop discrimination. Individuals may also file complaints with the Attorney General, who is authorized to bring lawsuits in cases of general public importance or where a oepattern o practiceî of discrimination is alleged. In these cases, the Attorney General may seek monetary damages and civil penalties. Civil penalties may not exceed $55,000 for a first violation or $110,000 for any subsequent violation.
Right on MH and in CA & FL you can sue outside of Federal Court and collect damages, but not in the Republic of Oregon? (smiling).
The correct intent for enforcement of ADA laws
Failure by these states to require negotiations through an arbitration board/agency or permitting a private party to negotiate a "settlement" under threat of a lawsuit is not the intent of the ADA as MH pointed out. It was never the intent of the feds to have individuals suing other individuals/businesses to achieve ADA compliance. It is the responsibility and job of the DOJ
mtlogcabin said:
The correct intent for enforcement of ADA lawsFailure by these states to require negotiations through an arbitration board/agency or permitting a private party to negotiate a "settlement" under threat of a lawsuit is not the intent of the ADA as MH pointed out. It was never the intent of the feds to have individuals suing other individuals/businesses to achieve ADA compliance. It is the responsibility and job of the DOJ
I never, ever said a lawsuit is the intent of the ADA and anyone can file a civil action in any state
You may file a complaint to the DOJ and or file directly with the federal court of of that jurisdiction
mtlogcabin said:
The correct intent for of ADA laws
The intent of the ADA is to provide equal opportunity and access for people with disabilities.
The intent has nothing to do with enforcement .....
kilitact said:
And the code section is what MH. The dance continues without any solid steps.
Are you asking what authority the DOJ has to enforce federal law?
Or what gives citizens the right to file lawsuits to protect their civil rights?
Start with government section 29 CFR 1601.28 - Notice of right to sue: Procedure and authority.
I am not an attorney, though I play one sometimes, check with yours.
mark handler said:
Are you asking what authority the DOJ has to enforce federal law?Or what gives citizens the right to file lawsuits to protect their civil rights?
I'm talking about code sections that code officials enforce. Your again talking lawsuits which I have no interest in.
As I have said repeatedly, Code Officials DO Not enforce the ADA, unless your State requires you to do so. You obviously do not have that authority, You must enforce the accessibility laws and codes in your jurisdiction. Architects, Engineers and Designers are required to design to the most restrictive, that includes the ADA.
When posters do not identify what role they play, my responses are to the most restrictive, that includes the ADA.
My mistake for not being as clear as clear can be: We generally allow them if above the tolet tank, and at least 12" above the grab bar
mark handler said:
As I have said repeatedly, Code Officials DO Not enforce the ADA, unless your State requires you to do so. You obviously do not have that authority, You must enforce the accessibility laws and codes in your jurisdiction. Architects, Engineers and Designers are required to design to the most restrictive, that includes the ADA.When posters do not identify what role they play, my responses are to the most restrictive, that includes the ADA.
So, cite a code section from ADA requirements. Or are you just stating your opinion has to what might probably be the imagined intent?
Sec. 12188. Enforcement(a) In general(1) Availability of remedies and proceduresThe remedies and procedures set forth in section 2000a-3(a) of this title are the remedies and procedures this subchapter provides to any person who is being subjected to discrimination on the basis of disability in violation of this subchapter or who has reasonable grounds for believing that such person is about to be subjected to discrimination in violation of section 12183 of this title. Nothing in this section shall require a person with a disability to engage in a futile gesture if such person has actual notice that a person or organization covered by this subchapter does not intend to comply with its provisions.(2) Injunctive reliefIn the case of violations of sections 12182(b)(2)(A)(iv) and Section 12183(a) of this title, injunctive relief shall include an order to alter facilities to make such facilities readily accessible to and usable by individuals with disabilities to the extent required by this subchapter. Where appropriate, injunctive relief shall also include requiring the provision of an auxiliary aid or service, modification of a policy, or provision of alternative methods, to the extent required by this subchapter.(b) Enforcement by Attorney General(1) Denial of rights(A) Duty to investigate(i) In generalThe Attorney General shall investigate alleged violations of this subchapter, and shall undertake periodic reviews of compliance of covered entities under this subchapter.(ii) Attorney General certificationOn the application of a State or local government, the Attorney General may, in consultation with the Architectural and Transportation Barriers Compliance Board, and after prior notice and a public hearing at which persons, including individuals with disabilities, are provided an opportunity to testify against such certification, certify that a State law or local building code or similar ordinance that establishes accessibility requirements meets or exceeds the minimum requirements of this chapter for the accessibility and usability of covered facilities under this subchapter. At any enforcement proceeding under this section, such certification by the Attorney General shall be rebuttable evidence that such State law or local ordinance does meet or exceed the minimum requirements of this chapter.
This is the fabricated code section you are to lazy to look up.
As I have stated before You are not empowered to enforce the ADA
kilitac - note that what MH cites is the Federal mandate to enforce claims. If in your state, unlike in CA, FL and others they have not created a seperate mechanism in addition to the Feds then he is right, however if your code has been certified (has it?) then you, as a BO would be responsible for strict ADA compliance when enforcing your code as would your code enforcement officers who would/could investigate such claims.
This is why state codes should have been certified in order to take the Feds out of the enforcement game. Here lack of funding for staff at DOJ limited their turnaround on certifications to date (smiling)
Hindsite indicates that BO's missed an opportunity to collect fees for failure to issue and enforce citations for non-compliance had their codes been certified and supported by state governors & attorney generals (political positions!)
We enforce what has been adopted, not what someone imagines to perhaps be the intent. Again the point was that Sec. 609.3 allows 1.5" below and 12" above. If you have code sections that state otherwise post it. MH stock apears to be based on lawsuits and name calling which don't equate to enforcement.
