Yikes
I have a not-for-profit affordable housing client that is renovating the tired-looking exterior of some old apartments. The apartment bedroom windows do not meet current code for emergency egress, but they believe it was legally permitted in the 1950’s.
These windows on the apartments have lead-based paint, and the paint removal process on the window frame and trim would be so extensive that they would dislocate the tenants during the renovation, which they cannot afford to do. Some window subcontractors have presented a retrofit window alternative that would essentially fit inside the existing aluminum–frame window opening. The problem is, the frame makes the already-too-small egress window opening about 3” smaller in each direction.
If this were in your jurisdiction, what would you recommend? could you "grandfather" the replacement windows in? Keep in mind they cannot afford to tear out the old windows and frames.
