Smoke detectors
the law will now change due to this death, most likely. it is sad that it takes tragedy to get changes put in place.
ok is this a play on words???
yes they are required, as in alot of cities and states.
But once installed, in private residence, what authority does an ahj have to go back and inspect for working detector??? Plus, would you want that law on the book??
This seems odd to ad to the story, perhaps there was something wrong with the heating system that spawned the purchase.
Contrary to what authorities reported, Ben Johnson III’s father said that his son was awoken by a smoke and carbon monoxide detector the family had just purchased that evening.
1965 house, SD's not required. Maybe they were installed in conjunction with a remodel covered under more current codes. Even in a new home, as cda points out, they have to be there for the final, we can't require the stay or be maintained. Sad......but true.
Code required Residential Fire Sprinklers would have saved lives and property but the NAHB will fight to the death to build the cheaper homes without regard to the losses of the unfortunate who fall victim to home fires!
Smoke detectors have run their course and fire deaths and property losses will remain a fact of life until we debunk the lies and misconceptions and require fire sprinklers in new housing stocks ...
The HBA will put sprinklers in new homes its just a matter of when!
This breaks my heart...
I'm going to double check mine right now.
The un-answered question is what are the acceptable loss numbers before applying more and more regulations
If you believe sprinklers will eliminate all loss of life in a fire then you are living in a dream world.
"Code required Residential Fire Sprinklers would have saved lives and property but the NAHB will fight to the death to build the cheaper homes without regard to the losses of the unfortunate who fall victim to home fires!"
The house in question was 47 years old. Residential sprinklers will make a negligible difference in residential fire deaths for another century or so unless they are also required to be retrofitted to all existing houses. Retrofit is likely to cost a little more than the often quoted $1.61 per SF, probably more like $11.61 or $16.10! Not too many people can afford this.
The fanatical RFS bunch must be a blissful group as they march in unison to the whim of NFPA and NFSA. Considering that the 2009 codes sold so poorly and the 2012 are not doing much better it is very clear what jurisdictions and legitimate code officials think of RFS. It is reprehensible that a special interest group was permitted to buy memberships and in turn saddle the ICC with this BS.
I can go either way on residential sprinklers.
Yes I prefer them to be there
I guess why not the same arguement for commercial buildings?? Why haven't the no sprinkler people stepped up and tried to get the commercial sprinkler requirement removed from the codes???
cda said:
I can go either way on residential sprinklers.Yes I prefer them to be there
Because the higher occupant loads and the occupant's lack of familiarity with the building tells us that the cost of installation vs. lives saved does not constitute an unreasonable investment (well below 3 million dollars per life saved while residential sprinklers cost 38 million dollars per life saved). In jurisdictions that have mandatory sprinklers in single and two family homes the survivability goes up by .1% over a home with working smoke detectors. I would like to see sprinklers in every building, but common sense tells us that spending that much money for a .1% survivability increase should be a decision made by the owners, not a code requirement.
do you have a source link for those numbers???
Commercial buildings required to have sprinklers are usually 12,000 sq ft or more, have a large occupancy load, or people that are not capable of self preservation.
Commercial sprinklers are designed to protect property. RFS are not even though they are constantly being sold that way.
I personally would like the sprinkler requirement in R-1 and R-2 removed in buildings of 2 stories or less if each dwelling/sleeping unit has an egress door that leads directly to an exterior exit access that leads directly to an exit.
cda said:
ok is this a play on words???yes they are required, as in alot of cities and states.
If it is commercial property (apartments/hotels) they typically have this right for anual inspections.
But for residences (in part due to numbes and privacy concerns) they wouldn't.
Really, the big factor would be the underwriters pov. Could they refuse to payout a claim due to lack of operational alarms, etc?
Question would be, for live/work units in sfr, make the property commercial enough to allow for occupancy inspection requirements that mfr/comm propoerties currently have?
Otherwise, one could include it with condition on resale of property.
Last, the author doesn't realize the code requirements are gradient in a natures, when comparing apples and oragnes (sfr/mfr).
Code has always place greater requirements where it affects more and more.
No I do not think that is bad in practice.
Yes that does mean tragedies will occur.
But no matter what we do, there is always going to be a point where these things will happen.
While you debate whether adding fire suppression to sfr's, I think it would be better to restrict operation of windows to prevent fall hazards.
But to each their own pov.
MT,
The far right advocates for RFS won't even consider a compromise of similar resolve.........go figure:banghd
Some people just can't see the forest beyond the trees!
It appears that the news reports are mistakenly referring to smoke alarms as smoke detectors. It is some consolation that the fire department was able to use this story to emphasize specific prevention measures to the community.
As far as mandating sprinklers in all new housing in order to protect daycare centers in existing homes, I fail to see any benefit for the children.
To support tmurray's statistics that residential fire sprinklers in new construction (which would be installed alongside hardwired interconnected smoke alarms) would make less than 1/2 of 1 percent difference in survival statistics can be seen in a 2008 NFPA report which cites a 99.45% chance of surviving a home fire when working smoke alarms are present. In the 2011 NFPA Report that survival rate is up to 99.59% for hardwired smoke alarms (99.99% with hardwired smoke alarms and wet pipe sprinkler protection).
hlfire: Didn't do any good. However, I agree with aegisFPE. As stated above I have been on both sides of the coin on this issue. I voted against them in the twin city mess and in Baltimore. I have spent countless hours reviewing all positions. In some AHJ's I inspect and enforce the requirement for Sprinklers. In other AHJ's they are not required under PA UCC. I have a different view than several years back on the need or not for sprinklers. However, as we have seen ICC has not fared well since the mandate to their code books and states have not approved them.
Somke alarms are great but you have to be capable of fleeing from the fire. Smoke alarms are passive protection and sprinklers are active protection. Get on the e-mail list for fire deaths from (non-arson) residental fires. Every day many many deaths of babies and elderly that are unable to respond to smoke alarms. We (the fire service) did not come up in arms over brace walls in residental structures. I can sprinkler a home for less than I can install brace walls. Heck I can sprinkler a home for less than they charge to paint it. IMHO Off soapbox now!!!!
