Architecture for Dummies?
IMO It is lazy and irresponsible to not know what the codes are for the place you are building. It is an easy search to find out, or a quick phone call, 5 min. up front is all it would take. If I were the client I would not be happy with the design team.
It would be easy to say this is expected from of an out of state DP with our state stamp, but I see it from local DP's all the time as well. Part of it is the result of the myriad of different editions of the codes adopted by each AHJ. Still, it just seems like just a few minutes up front would be worth it, and should be expected.
Up.codes's list is not complete, they just stuck with the large jurisdictions. For a complete list of California jurisdictions that have filed amendments to the state building code, see:A quick review of UpCodes shows that only a few jurisdictions do this:
YC, are you looking for the minimum on plans for the purpose of plan check, or also the minimum on plans for best practice of avoiding field problems?I often hear building official colleagues complaining about the quality (or lack thereof) in the plans they receive for permits, and the frequently repeated lament is "Somebody ought'a write a book."
I'm an architect, and I'm also a writer. Over the years I have had articles published in several trade and professional magazines, I've written a number of (self-published) books, and I've even had a feature article in Fine Homebuilding magazine. So I've decided that if a book to tell architects what we need to see in construction drawings needs to be written and nobody else has stepped up to the plate, I may as well do it.
With that in mind, please let me know -- either with posts in this thread or by PM -- what you think architects need to be told to put in their drawings.
Thanks.
Shouldn’t those go hand in hand?looking for the minimum on plans for the purpose of plan check, or also the minimum on plans for best practice of avoiding field problems?
Not always. It depends on the project procurement method.Shouldn’t those go hand in hand?
I received one today with the wrong codes and the wrong construction type, has notes for a completely different AHJ, it was a single page for the architectural, no sections, interior details, RCP, door tags or schedules, finishes, framing plans or details, exterior or interior elevations or details, accessible details of any type, to name a few important elements. It is a first time tenant in a brand new core/shell, decent size A2. Maybe some think a 1-pager with none of these things is fine, but IMO it does not get anywhere near to being of sufficient clarity to determine code compliance. We even have a submittal document that lists many of these very things in case the DP doesn't understand this. This is the 2nd submittal, because the first was little better than a napkin sketch and I rejected it outright and explained exactly what should be submitted. I got this one page back.
In CA, charter cities can have their own codes....Here in California, once the state adopts a code, the local municipalities must either adopt that code or propose amendments within a certain time period. A quick review of UpCodes shows that only a few jurisdictions do this:
There may have been a time or two, but typically I conduct the review based on the adopted codes, which usually doesn't reveal a lot of deficiencies because the wrong code edition was referenced or used in the design. I then just include the comment to provide reference and design to the adopted code along with my other comments. If the codes were not even close and/or I start to see multiple issues because of the different codes then I would reject it. I will not "approve" a plan with incorrect code references.I would like to know if any plan reviewers reject the plans right away when they have the wrong codes on it, or do you review everything anyway?
