R308.1 Identification. Except as indicated in Section R308.1.1 each pane of glazing installed in hazardous locations as defined in Section R308.4 shall be provided with a manufacturer’s designation specifying who applied the designation, designating the type of glass and the safety glazing standard with which it com- plies, which is visible in the final installation. The designation shall be acid etched, sandblasted, ceramic-fired, laser etched, embossed, or be of a type which once applied cannot be removed without being destroyed. A label shall be permitted in lieu of the manufacturer’s designation.
1. For other than tempered glass, manufacturer’s designations are not required provided the building official approves the use of a certificate, affidavit or other evidence confirming compliance with this code.
2. Tempered spandrel glass is permitted to be identified by the manufacturer with a removable paper designation.
Clearly the code allows a label in lieu of a designation and a designation carries the description as something "which once applied cannot be removed without being destroyed." There is no indication that a label carries the same description and in fact, spandrel glass "is permitted to be identified by the manufacturer with a removable paper designation." So there we have a "designation" that's a removable paper designation (read label) whereas just above that, a designation was identified as something other than a label.
It is noteworthy that only spandrel glass is allowed to be identified with a "removable paper designation but a label can be used in lieu of a designation." Indications are that a label is not removable paper.
For other than tempered glass, a designation is not required so apparently safety glass is exempt as is heat strengthened glass.
To further confuse me, there are two tables that generate questions like "What the heck are they talking about."
There you have it. Your guess is as good as mine. Maybe somebody here has a handle on it but for now I ask for, and have been getting, etched glass. As I stated earlier, I've not been presented with a label. I either find etched glass or nothing and when I ask for proof, etched glass is installed.
The first time I am exposed to a label, I will ask how am I to be sure that it is a label since there is no clear understanding of what is a label and, just as important, what is not.
I know that what I have posted here is no help with your situation.........Get a letter from the manufacturer.
