UL design number of a demising wall adjoining a shower
What's the UL listing of a demising wall that shall have a two-hour fire rating but also adjoins a shower?
Is there a specific UL listing for this type of wall (Cement board+tiling), instead of the two layers of MR boards?
Build and apply covering per the UL listed wall, then install the shower. I have not seen a 2 hour listed premade shower or tub
Please see below
1-Non-bearing wall
2-No specific STC rating required
3-It's located between two apartments
4-The shower stall is on one side only
The only unknown is where the cement board joins the drywall. The joint compound needs to be compatible with both. Perhaps a 1/4” gap filled with intumescent caulk is a good idea.
