Builder Bob
Sawhorse
While not in the Building Code, this is from the fire code. This requirementy does not go away with sprinklers and open yards without other (non-code) required alternate fire protection features such as standpipes, dry hydrants, etc. that are acceptable to the authority haivng jurisidiction. (see exception number 2.)
503.1.1 Buildings and facilities. Approved fire apparatus access roads shall be provided for every facility, building or
portion of a building hereafter constructed or moved into or within the jurisdiction. The fire apparatus access road shall
comply with the requirements of this section and shall extend to within 150 feet (45 720 mm) of all portions of the
facility and all portions of the exterior walls of the first story of the building as measured by an approved route around the
exterior of the building or facility.
Exception: The fire code official is authorized to increase the dimension of 150 feet (45 720 mm)where:
1. The building is equipped throughout with an approved automatic sprinkler system installed in accordance with Section 903.3.1.1, 903.3.1.2 or
903.3.1.3.
2. Fire apparatus access roads cannot be installed because of location on property, topography, waterways, nonnegotiable grades or other similar
conditions, and an approved alternative means of fire protection is provided.
3. There are not more than two Group R-3 or Group U occupancies.
903.3.1.3.
