Builder Bob
Sawhorse
I don't totally disagree with his concept. However, working in a newbie Building department ( formed in 1997 and started working in 2001) allowed me to experience alot of growth and birthing pains as the department became more proactive.
Prior to 1997, a conctractor applied for a permit, filled out an affadavit of completion, and could apply for a Certificate of occupancy the same day...... Now the process is longer.
Some observations along the way-
The bad contractors never pull permits --- thus the people looking for a deal are still getting screwed
The more lucative jobs - are using qualified contractors -
The residential contractor is using the department to do his job for providing punch lists for construction -
on the flip side,
-- bad contractors are becoming more "public" knowledge
-- It does help regulate contractors in the field with licensure.
-- Building Quality has drastically improved over the past decade
- --for example, a house built pre- inspection day was often found to have spot footings of 12 X 12 but only 3 to 4 inch thick.
---- ---------- GFCI are often lacking or missing
--------------- Wiring splices are predominate -- end or roll of romex, add more conductors (often plain THHN wire)
--------------- Meter Bases and Panel Boxes are always an adventure -
The improvement of building construction in our region is from the requirment of contractors to pull permits to past a basic requirment for building construction and from failing inspections because the contractor failed to stay current on code requirements.
(SC only requires a knowledge of basic building code requirements to obtain the license - No CEU's are required)
The idea of workmanship and craftmanship are a thing of the past----- The bottom line is how much profit I can make and the current economy does not support the cushioning of the jobs for profit as inthe past.
This article is nothing more than complaining:
(a)He is doing the right thing and others aren't; (or)
(b) He has been caught with unpermitted work and fined numerous times -
on the flip side,
