CGH
Using the performance compliance method to evaluate a building, if the evaluation in the tables results in "NA" do you transfer the "NA" to the columns in Table 1301.7 Summary Sheet or do you have to comply with another column? Similarly, specifically in sections 1301.6.14 Elevator control and 1301.6.15 Means of egress emergency lighting, if the evaluation results in "NP" do you fail the evaluation like it is stated in section 1301.6.17 Automatic Sprinklers for I-2 columns a, b, c, or f, or do you have to comply with another column?
