TimNY
View attachment 784I think that says it all...View attachment 378jar546 said:BTW, it is a PE from NY State.
/monthly_2011_02/homer-doh-square.jpg.e27883eeb4136beda5b3162a4a01d675.jpg
Licensed in your jurisdiction?jar546 said:BTW, it is a PE from NY State.
Note reference to "abnormal" condition....an indicator that abnormally high solids/wastewater levels have occurred at times.
Again, note reference to "abnormal" condition....indicating abnormal backups occur.
Note test flow was less than half of peak design capacity.The water flow rate was measured at 5 gpm. A Hydraulic water load test was terminated after 25 min. (125 gals.) due to the abnormally high wastewater level rising to the top of the tank manhole opening. A minimum design capacity of an absorption field for a 3 bedroom is approximately 350 gals. with a peak flow capacity well above that amount
The author identifies that there is "critical missing" information needed for further evaluation.The location and size and condition of the field is a critical missing item needing further identification and evaluation.
Just out of curiosity, why are you involved in this as an inspector?jar546 said:Good question. He did not stamp the letter or put his number on it, just his name and PE
Agree by reading the report I would say the problem is in the drainfield and further evaluation would have to be conducted on the drainfield. The PE did is job.AegisFPE said:It seems as though people are reading this report and thinking the author gave a passing grade; I don't see it that way.Note reference to "abnormal" condition.Again, note reference to "abnormal" condition.Note test flow was less than half of peak design capacity.The author identifies that there is "critical missing" information needed for further evaluation.
I bet your friend would be happy to contract with the engineer to do this for him.The location and size and condition of the field is a critical missing item needing further identification and evaluation. This requires electronic detection and invasive excavation to evaluate distribution boxes, piping, aggregate and soil for contamination or excessive organic loading.
Most State's allow you to look up professional licenses online - But I don't know about Dunder Miffin. Also, some states require engineering reports to be sealed.jar546 said:Good question. He did not stamp the letter or put his number on it, just his name and PE
No he said it was "Unsatisfactory" in the very begining of his report.He stated the system was satisfactory.
Last week, I diaqnosed a Septic system to be ‘Unsatisfactory’ due to it’s inability to maintain functional flow to the Absorption field. I substantiated my conclusion with the following observations being noted in my report:
I think you are confused. That language is from the inspector's report.mtlogcabin said:No he said it was "Unsatisfactory" in the very begining of his report.
You're right, I was!jar546 said:I think you are confused.
Thanks for the clarification. :agree The Septic contractors report is more thorough and professional than the engineers. Tell him to be careful he might be charged with praticing engineering without a liscense. No wait the septic contractor was factual the engineer is the one who had no clue and was praticing writing a septic inspection report.jar546 said:I think you are confused. That language is from the inspector's report.The language stating that it is satisfactory is in the PE's report which was a link provided on the original post.
I don't put stamps on my work. I don't put my number on my work.jar546 said:Good question. He did not stamp the letter or put his number on it, just his name and PE
Without a number I can't verify you are liscensed to pratice engineering in my state.. So your name and signature on your work is just that a name and a signature.I don't put my number on my work.
I'm curious what states allow the practice of engineering, and the preparation of construction documents without a seal. In what states are you licensed to practice, GH Roberts?GHRoberts said:I don't put stamps on my work. I don't put my number on my work.My name always appears just below my signature. That is enough to make my insurer happy.
Jar you are unhappy with the professionals work. But you are not the one paying for it. You have no standing. No reason to demand better of the fellow.
The letter regarding the septic system was not a construction document. Commonly a seal is only required on documents filed for public record - though state law varies.texasbo said:I'm curious what states allow the practice of engineering, and the preparation of construction documents without a seal. In what states are you licensed to practice, GH Roberts?
