Forum Coordinator
If it ends outside the house then do exterior steps from an attached, covered front porch have to be compliant and covered under the building code? IRC specific discussion.
Attached is the key word for me, so yes.By extension, how about the NOT attached concrete steps that lead from the front walk to the driveway?I say rise and run, definitely. But how many are enforcing handrails/guards?View attachment 916jar546 said:...steps from an attached, covered front porch...
Deleted--RJJ said:is an egress widow well with a ladder to dirt covered? No! Does the code require it ? No!
I used the word covered but should not have. My point is a from porch that has a cover or a rear open deck, does not matter as long as they are all outside of the house.mjesse said:Deleted--I mis-interpreted your post.
Me thinks Jeff means "covered" as in "included in" the Code, not "covered" as in "a cover/roof over"
mj
The guards are a good example for this discussion, as any attempt to use the code to exclude stair geometry would also exclude these guards. At least the arguments I've heard so far. This is why I bring it up.RJJ said:We have responses to guards etc. The question is I suppose, do the steps have to be covered / have a roof. I say no.
There are many that say the stairs from a deck or porch are not covered by the code because technically you have already egressed the house and are outside.High Desert said:I really don't see any confusion where it ends. I think the code is pretty clear.
jar546 said:There are many that say the stairs from a deck or porch are not covered by the code because technically you have already egressed the house and are outside.
