Francis Vineyard
To restate if the panel is move forward and mounted so as the rear of the panel is beyond the gas pipe then the pipe is behind the dedicated space. That would be compliant IMO.Glennman CBO said:I'm not an electrical guy, but can the dedicated space be measured from the face of the panel? If the panel was, say, 12" from the wall, would this reduce the dedicated space's depth by 12", thus giving you only 24" in front of the panel (I'm guessing that the dedicated space is 36" deep)?In other words, is the depth of the panel included in the depth measurement? This surface mount panel would give you less depth than a "flush" panel at its front.
However in the OP the panel was set first and then the gas line, either way hopefully someone will have a learning experience.
