NBC - Distance between windows in townhouse
jackart
Winnipeg, MB
Hello, currently working on a townhouse design and wondering if there any limitations on distance between windows of adjacent fire compartments (suites) in townhouse. The same should be applicable to apartment building. However I can’t find anything in NBC. The wall is straight, no angles less than 135degrees. Thanks in advance.
Welcome
There is someone from up north that speaks nbc
If like down here there is a firewall between townhouses,,, where apartments do not have that.
Down here, I think you cannot have an opening within,,, maybe three feet or five feet
Give it a few days for great answers
Thanks everyone for your answers. I’ve read that it should be addressed with max 135degrees only condition because if it’s 180degrees then there is no concern based on how the fire develops. Sounds a bit weird because there is still heat transfer but in reality you can have wall (not a firewall) between suites and windows attached to this wall from each side and it’s code compliant.
