A 4x4 and one of these would do the trick. After all, the siding a trim guy needs backing around the windows. Even us folks in stucco-land provide backing for window trim. Actually, I should have said two of those...you'll need one at each end of the 4x4.That's me.
There is much more here that I have not discussed in order to focus the discussion on the key point. Suffice it to say that it would be a huge headache to add a header and no chance of using jack studs. Some weird sort of hanger would have to be used.
30% of the time you have no clue if the correction was right or wrong. 60% of the time you didn't get a code reference and you were okay with that. If I was right 10% of the time I would hang it up. 100% of the time the inspector was toiling away.Curious as to how/if this was resolved.
My 2 cents as an architect:
1. If the inspector has a problem with what they are seeing in the field, he should provide a code citation. If not, they should let it pass.
2. If the inspector sees a code deficiency in the plans that somehow managed to slip past the plan checker, he should provide a code citation.
3. If the inspector is not sure but thinks their might be a code deficiency, and the plans seem silent on the issue, and he wants a clarification from the DPOR prior to approving the inspection, he should provide a code citation.
The inspector should not be the one to initiate the call to the DPOR. It is possible the DPOR gets paid hourly during construction, and the owner will want to remain in control of their A/E budget. Instead, with the code citation, the owner is free to pass it along to the DPOR, then the DPOR initiates the call to the inspector.
I've had superintendents call me in a panic saying the inspector has a problem. I tell the superintendent to make me the bad guy, and tell the inspector I want him to write it up, including the applicable code reference. 30% of the time, the problem goes away right then. 60% of the time, a clarification call or email from me will lay the issue to rest. 10% of the time, the inspector was right, and I'm glad he found the issue and brought it to our attention.
Just got off the phone with an MEP engineer out of state. I find they greatly appreciate reasonable discourse and questions in an effort to achieve the goal, which is to move forward. Nothing wrong with honest questions.The issue is the absence of a header over a window in a gable end (nonbearing exterior wall). The inspector has been okay. It's his boss that cannot make a decision up or down and won't return any calls. I have sent them plenty of info making my case. No response.
I also have a related question: Is it proper for an inspector to directly contact my engineer or architect or even customer without going through me. Because this code official does this all the time as well. My engineer is irate.
Being 90% gets you into several "halls of fame" and millions a year......ICE, to clarify:
My comment is not about the number of times an inspector finds something wrong with the construction. That happens all the time. In the context of this thread, my comment is about the number of times the inspector says something is wrong or missing with the DESIGN on the approved plans.
I said that when I ask for a correction inspector to write up a citation and reference the applicable code, 30% of the time they don't write it up; I suspect that's because they dig into the code and find out the plans are in compliance.
60% of the time, they cite a code, and then I have a basis upon which I can demonstrate code compliance to them and convince them it' still OK.
10% of the time, they find something legit.
And to be clear, that doesn't mean my plans are 10% defective; otherwise, I should hang it up, too.
I am referring solely to that much smaller and rarer subset of inspector citations for issues that he might have with the approved permit set of plans - - something that both the DPOR and the plan checker may have gotten wrong.
He is a sawhorse member which allows you to cut and past photos in. Otherwise you place them somewhere else and provide a link to themBtw, how do you paste those code sections in like that if they are in picture form?
I have always known that you have a well developed imagination. I figured that it was a thread about some guy that pissed off an inspector.Is it just me or does anyone else think that the heading for this thread could have been written better? "Unresponsive Inspector?" How about "Lack of response from inspector?"
When I first saw this I thought it was a thread about an accident
I've seen your pictures....More like Third World issues......... Then off I go to real world issues.
On a simple gable roof system. The gable ends are not load-bearing walls. They usually will only have a single header plate at top of wall. In which case, that will would not need a header over the windows or doors. Only on the load bearing walls would you actually need it. However, having said that, there may exceptions to the rule. Say, parts of the gable-end wall must have a shear braced and the gable part above the the windows, and doors and along the sides or where a brace wall pattern is required, there may need to be continuous header over the windows and doors. Headers would be as thick as the wall and the height of the header (top to bottom) would be like any beam which needs to carry the above deadload and other applicable loads without deflecting to unacceptable levels across the span of the opening for windows or doors. For typical size windows and doors not exceeding 4-ft. in width, a 10" to 12" tall header should suffice and support the loads. If you can not determine this, consult a design professional (architect, engineer, or a competent building designer (likely one that is certified as a CPBD [certified professional building designer]). They should be able to figure this out for you. I can not with absolute certainty, answer the OP's question on a professional capacity without a very thorough review of the design.
If the header area of the window is in the parts of the wall for shear resistance then it is necessary to have a header and it also provides for a nailing point for shear wall panels. Gable-end wall might not be directly supporting the floor loads but it may need to be designed to resist racking. I would, if I was designing the home unless that is adequately addressed elsewhere. This is for not just seismic for also hurricane force winds. Where I am, we are in a special wind zone category and designing would need to be designed for wind speeds upwards of 150+ mph (potential) and seismic zone to deal with earthquakes in the 8.5 to 9.5+ magnitude scale (subduction zone megathrust earthquakes). Therefore, design-wise, I would be looking to that level and up to 175 (maybe even 200) mph (depending on location and open exposure). Therefore, even the gable-end would need to be adequate shear resistance.
For headers above doors and windows, there a section on it in the IRC and IBC. Look at the index and look for what section it's listed and go there. Design professionals should be familiar with the code book and how to look through it. Ideally, so should clients/property owners get their head around it as well.
