You would as allow non-uniform wonders? In a spiral stair some treads 30 degrees, some 45, etc? I sure wouldn't.Winders are non-uniform and non-parallel edge type treads.
What you might perceive as a search for a reason to fail something, I might see as a search to get it right. How does one search for a reason to allow something? More to the point would be why would an inspector feel compelled to do that search? That gives me the thought that when faced with some sketchy thing I should find a way to bless it. Inspectors are not wired that way.Why do so many Building Inspectors always search for a reason to fail something they don't personally like, rather than search for a reason to allow what someone spent a lot of money on to have a certain way?
sure seems like uniform treats are required on winders to me:Bill,
To simplify re-read the 2018 IRC, I believe section R311.7.5.2.1......
The uniform tread depth requirement of 3/8" is only measured at the "walkline" on winders!
A spiral staircase is not a winder stair flight, they are eggs and bacon, go good together, but they are not the same thing.
Spiral staircases are noted to be uniform in their tread pattern, winders are not.
Here is the question I have,
It does not matter how much money someone spent to have something done a certain way.Why do so many Building Inspectors always search for a reason to fail something they don't personally like, rather than search for a reason to allow what someone spent a lot of money on to have a certain way?
Bill Re-Read the section:sure seems like uniform treats are required on winders to me:
(from 2018 IRC)
Winder treads.
Winder treads shall have a tread depth of not less than 10 inches (254 mm) measured between the vertical planes of the foremost projection of adjacent treads at the intersections with the walkline. Winder treads shall have a tread depth of not less than 6 inches (152 mm) at any point within the clear width of the stair. Within any flight of stairs, the largest winder tread depth at the walkline shall not exceed the smallest winder tread by more than 3/8 inch (9.5 mm). Consistently shaped winders at the walkline shall be allowed within the same flight of stairs as rectangular treads and shall not be required to be within 3/8 inch (9.5 mm) of the rectangular tread depth.
While that may be possible in the stairs in the photo, where or how would you measure? On the radius, length of an arc?
Of course they are there to assure compliance, my point is a portion of inspectors will be shown many times over that a design complies, and then simply say I don't like it and I don't think it complies and won't pass it, and will cite just about anything out of the hat.It does not matter how much money someone spent to have something done a certain way.
Inspections are done to assure compliance. Some inspectors are black and white on what the code does and does not say, others will look at the intent of the code section and make a determination from there.
It's simple:While that may be possible in the stairs in the photo, where or how would you measure? On the radius, length of an arc?
When I’m having trouble understanding, I read it a few times and then come back to it a day later and read it again. Let us know how that worked out for you.Not sure why this is hard to understand.
That's what I do with the NEC?When I’m having trouble understanding, I read it a few times and then come back to it a day later and read it again.
Works fine for me ICE, unlike most inspectors, for the past 25 years, stair, handrails and guard configurations and the code sections in those books are all I do.When I’m having trouble understanding, I read it a few times and then come back to it a day later and read it again. Let us know how that worked out for you.
Have known Dave Cooper for over 25 years, he is the SMA's code representative, and then one of the main writers of the Visual interp guides they have been publishing since 2003.That's what I do with the NEC?
