Random Photos & Thoughts
The Corinth Canal (Greek: Διώρυγα της Κορίνθου, romanized: Dioryga tis Korinthou) is an artificial canal in Greece that connects the Gulf of Corinth in the Ionian Sea with the Saronic Gulf in the Aegean Sea. It cuts through the narrow Isthmus of Corinth and separates the Peloponnese from the Greek mainland, making the peninsula an island. The canal was dug through the Isthmus at sea level and has no locks. It is 6.4 kilometres (4 miles) in length and only 24.6 metres (80.7 feet) wide at sea level, making it impassable for many modern ships. It is currently of little economic importance and is mainly a tourist attraction.
The canal was initially proposed in classical times and a failed effort was made to build it in the 1st century AD.[4] Construction recommenced in 1881 but was hampered by geological and financial problems that bankrupted the original builders. It was completed in 1893, but, due to the canal's narrowness, navigational problems, and periodic closures to repair landslides from its steep walls, it failed to attract the level of traffic expected by its operators.
Sheet metal duct tong puller with grip.​
Is great for use in the HVAC industry for pulling sheet metal duct work together. Were alignment is off.
Finest grade tool steel. 14: in Length. Opens to 1-7/8"
I've always know those as Oetiker Pliers. Oetiker being a brand, with the actual name being ear clamp pliers or pincers. Many different uses, but commonly used for pinch clamps on poly irrigation pipes.
I first used them as laminate (formica) trimmers, for when you get up tight to a wall and the router bit quits. Gets it close enough to file at the point.
I also used them to pull finish nails without damaging the surface (too much).
I also use them as classicT describes.
I think we are seeing a trend, they are a multi-purpose tool.
And horse hoof trimmers for when they are getting new shoes.
Reactions: ICE
This is another motorbike that Rembo is considering buying.
It's for his "Rough & Ready" rides.
Anybody remember the AMC Gremlin ?
We were in Wytheville, Va last weekend at the same time the a Mini owners club was holding a meet. I had forgotten how tiny the original Mini Minors were. It could almost fit into the bed of the pickup truck!
Might alert tailgaters. Is it the mounting or location on vehicle or both that makes it "dumb"? I frequently see these 2 calling cans mounted on the side of RVs.
The current smallest City Hall in the U.S., ...Maskell, NE
Apparently you can buy some brains.
There's something not quite right about this particular birch tree.
