mtlogcabin
Do you know how that tool is used in the construction industry?
Horse maintenance.Do you know how that tool is used in the construction industry?
Similar to tile nippers.Horse maintenance.
That and horse maintenance.Sheet metal duct tong puller with grip.
Is great for use in the HVAC industry for pulling sheet metal duct work together. Were alignment is off.
Finest grade tool steel. 14: in Length. Opens to 1-7/8"
I first used them as laminate (formica) trimmers, for when you get up tight to a wall and the router bit quits. Gets it close enough to file at the point.
I also used them to pull finish nails without damaging the surface (too much).
I also use them as classicT describes.
I think we are seeing a trend, they are a multi-purpose tool.
