I think what scares me most is imagining what that serves. My mind is filling in the rest of the picture, it isn't pretty.
Should have used TR outlets, right?
In the 1960's my father had a project which utilized copper conductors that were pipe. Water flowed through the pipe to prevent it from melting.Someone told me a long time ago that water and electricity doesn't mix?
Where' the bonding?
So you’re one of those infamous drive-by inspectors … ?Drove by a project - tight on time to go somewhere else. At 50km (30 mph for you in the Excited States), I saw an ICF foundation with vertical rebar way far apart.
In this case, yes. Had three minutes to get to a ferry.So you’re one of those infamous drive-by inspectors … ?
I was poking fun, hope i didn’t offend you. Must be difficult to work around ferry schedules.In this case, yes. Had three minutes to get to a ferry.
I have a thick skin, and a sense of humour; but I figured it was worth explaining nonetheless.I was poking fun, hope i didn’t offend you. Must be difficult to work around ferry schedules.
LOL I just couldn't let that go.I was poking fun, hope i didn’t offend you. Must be difficult to work around fairy schedules.
Damn homophones.LOL I just couldn't let that go.
Looks like the ahj insisted on that after several go-arounds, and the contractor said “you want angle braces and bolts? I’ll show you braces!”I was searching for a picture related to headers when I came across this. The hardware and blocking was installed because the roof plan called for boundary nailing of every edge of the sheathing. The steel angles are at a minimum 3/8" and might be 1/2". It has been too long ago for me to remember the exact details. I was concerned about the added weight. Imagine what that cost.
CORRECTION:The hardware and blocking was installed because the roof plan called for boundary nailing of every edge of the sheathing.
yep...Nice that the wood was preasssured to work...What more do you need?CORRECTION:
I was completely wrong. I found another batch of pictures with the truth of the matter. My excuse is that it happened in 2017 which is around 20,000 inspections ago,
As it turns out, there was a wacky engineer on the job.
