hans@dha-architects.
can you use a standard shower unit in a type B unit, one with an actual threshold (4-6")? I have an apartment building going up, 10% of units are type A with roll-in type showers with 1/2" thresh, bars, etc., but the type B's we're looking to use standard units - the 2017 ANSI makes no mention of the 1/2" thresh under type B unit requirements where as type A directs you to section 608 requirements for showers, either roll-in or transfer, type B simply appears to only require blocking for bars and seat if not larger than 36"x36" - my MEP engineer is saying we need the 1/2" thresh as we're looking over some submittals now. If you can have a tub in type b units where there is a transfer seat, there is a much higher barrier to swing your feet over than if you were in a shower with a 4" thresh.
