I will do that when I have time..... with pictures.i would prefer your personal explanation rather than code text.
The hole is an opening in the exterior wall. The 1/4” gap between the cabinet and the wall will let water and bugs into the wall cavity.I understand the part anout no splices in the wall. But if you install a panel over an old hole, and there are no penetrations in the cabinet at the hole ... ?
It depends on the panel. Some are approved to be flush some are not. Some can be surface mount or semi-flush.Fair enough.
Now ... does the 1/4” gap mean the panels cannot be recessed?
312.2 Damp and Wet Locations. In damp or wet locations, surface-type enclosures within the scope of this article shall be placed or equipped so as to prevent moisture or water from entering and accumulating within the cabinet or cutout box, and shall be mounted so there is at least 6- mm (o-in.) airspace between the enclosure and the wall or other supporting surface. Enclosures installed in wet locations shall be weatherproof. For enclosures in wet locations, raceways or cables entering above the level of uninsulated live parts shall use fittings listed for wet locations.
Everything with a "foundation" under the IRC.....Everything is permanent other than a tent......
I would like to know the proper way too. We have very few stucco walls here, almost all are vinyl siding.The electrician always mounts the meter panel over a piece of house rap before the siding crew comes in.Would you guys cite someone for vinyl siding tight around a meter can? Or just strictly the gap behind? Asking for a friend....
Is a patio "slab" a foundation?
So you are okay with any rain, snow, moisture getting directly in the wall?
I'm in the dessert and we don't allow it. Stucco, vinyl, brick, etc. As stated earlier, most exterior boxes are not listed to be in stucco,brick, etc. Here we have the install WRB then cement board and mount the box to that and stucco to the cement board. If vinyl, usually installed on top of uni-strut after vinyl. Same with brick, box installed after brick. These areas are usually done first so the box can be set to get rough-in.
That is the weather resistant barrier's job. Siding's job is to protect the weather resistant barrier
Very true. The degradation is usually related to UV damage, so here int he Great White North, we can wait around for that kind of thing.I agree. The areas between the meters and panels is not protected if not installed first. Here that means the sun will destroy the WRB in a very short amount of time and then you will have a direct opening in the WRB to the wall behind it. We don't get much rain but when we do it is in large amount at once. 6" in 2 days last week.
yesWould that be East facing, if so, duh!
