fireguy,
The strappin I was making reference too is the nylon strap material used to hold three bundles of insulation together and some times used to hold a pallet of boxes together.
A spool of light wire, (bailing wire), might do the trick if you Zig-Zag the wire and staple to the bottom of the FJ. If your in a crawl space try to find galvanized wire.
There is flat metal strapping used in wall bracing but that will cost you $$$
pc1
pc1
