Well they're safe there.....it's not concrete.....it's sand and cement.We don't allow that much concrete in the front yard.
What gives you the authority for that?\ said:This valve was left in a crawl space where it had served a floor furnace for 56 years. The gas pipe was extended to the attic for a new furnace. The gas valve was closed for the pressure test. The correction said to provide a picture of the pipe with the valve in place and a picture of the pipe with the valve removed. I also asked for the valve.
A tool is required to operate the valve. A valve shall be accessible. There is no listing for the valve. I usurp authority. I'm going with the last one....that way I don't have to come up with a code section.What gives you the authority for that?
Still won't fly....We require landscape not hardscapeWell they're safe there.....it's not concrete.....it's sand and cement.
That's the beauty of abusing authority and I don't know what the codes were in 1960.If you cannot come up with a code section you are abusing your authority.Were listings required for valves 56 years ago?
Don't you have the historic codes? ICC sold a CD with historic codes on it last time I was in their store.That's the beauty of abusing authority and I don't know what the codes were in 1960.
We have the code books so I could find out. Whatever the code was in 1960 has no relevance to the reuse of a valve today. Mark K has confused cannot with will not.Don't you have the historic codes? ICC sold a CD with historic codes on it last time I was in their store.
Here is the latest valve for my collection. To my surprise there is a connector attached. It hadn't occur to me that they were utilizing connectors as a part of the gas system in the underfloor area.This valve was left in a crawl space where it had served a floor furnace for 56 years. The gas pipe was extended to the attic for a new furnace. The gas valve was closed for the pressure test. The correction said to provide a picture of the pipe with the valve in place and a picture of the pipe with the valve removed. I also asked for the valve.
The key to this valve is grease. Grease makes the seal. 56 year old grease.
Is there any major damage to the property or mostly cosmetic damage like this? Is the house on a hillside that's moving, if not what's the cause of the movement?The bricks are dislodged because everything on the property is moving towards the middle of the street.
