    Dismiss Notice
Electrical Panel Location
Discussion in 'Electrical Codes' started by James T Timler, Feb 17, 2020.
  1. James T Timler
    James T Timler Registered User
    Feb 17, 2020
    15
    0
    2019-12-19_20-31-14_947_LI (2).jpg I am looking at purchasing a small home. The electrical panel is located inside a kitchen cabinet, close to the floor and below a kitchen counter. I assume this is a huge violation for clearance. Any confirmation is greatly appreciated. Also, the electric hot water heater is located in closet next to the furnace. The romex wire comes out of the ceiling directly into the water heater. Does there need to be a secondary disconnect and conduit? All feedback is appreciated. I will try to post a picture as well.
    #1 James T Timler, Feb 17, 2020
  2. cda
    cda Sawhorse
    Oct 19, 2009
    17,983
    1,253
    Welcome
    Which great state or territory are you in??
  3. cda
    cda Sawhorse
    Oct 19, 2009
    17,983
    1,253
    How old is the house?
    I am not an electrical person.
    I think your water heater wiring is ok.
    Not sure why you panel is in the location it is???? Is this the only panel for the entire house?
    Is the electric meter on the outside in this area???
  4. jar546
    jar546 *****istrator
    7,649
    708
    The panel is in a horrible location and a major safety concern due to access.
  5. James T Timler
    Feb 17, 2020
    15
    0
    The property is located in Wisconsin. The house is 90+ years old. Originally built as a cottage but has been a permanent residence for well over half its age. The panel is updated with circuit breakers.
  6. James T Timler
    Feb 17, 2020
    15
    0
    Yes, it is the main panel for all of the house. The house is 90+ years old. Originally built as a cottage but has been a permanent residence for over 50 years. Panel is updated with circuit breakers. Electric meter is outside.
  7. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    10,658
    902
    The panel needs to have an open working space in front of it, at least 36 inches deep, 30 inches wide, and from floor to ceiling. You may be able to get away with simply putting a door over the panel for decorative purposes, but a cabinet will end up getting filled with stuff that will block access.
    NEC 110.26(A) – The working space about electrical service panel/sub-panel shall be at least 3 ft. in front of the electrical panel. The width of the working space shall be 30” or greater, and the height of the space shall extend from the floor to 6 1/2 feet or the height of the panel, whichever is greater.
  8. James T Timler
    Feb 17, 2020
    15
    0
    Thanks for the information. I tried to post a picture but I could not get it to work.[​IMG]
  9. cda
    cda Sawhorse
    Oct 19, 2009
    17,983
    1,253
    If you are not a forum supporting member ( cheap to join), you have to make the picture a link and post the link
  10. cda
    cda Sawhorse
    Oct 19, 2009
    17,983
    1,253
    Sounds like you might negotiate a little money to get the panel moved.
  11. James T Timler
    Feb 17, 2020
    15
    0
    Thanks, what is a number I should aim for? I am not sure if cost $1,000 or $10,000 to move a panel? Any further feedback is appreciated.
  12. James T Timler
    Feb 17, 2020
    15
    0
    I believe I am all signed up as a member but I do not believe I did the link correctly. A symbol instead of the image appeard.
  13. ADAguy
    ADAguy Registered User
    Sep 11, 2013
    4,552
    435
    What type of wiring? knob & tube/penny fuses?
    May be a precode install or a DYI.
  14. James T Timler
    Feb 17, 2020
    15
    0
    I did not see any K&T wiring. Anything that was visible to me looked like Romex. The panel has all circuit breakers and outside the house is a Generac back up generator wired into the main panel. My assumption is a permit was not taken out and a contractor did a cash deal.
  15. cda
    cda Sawhorse
    Oct 19, 2009
    17,983
    1,253
    There are two levels
    The paying one is sawhorse, I think $35
    If you click on the round circle looking person, top right
    Go to account upgrade
    Look for annual sawhorse
    And help keep this great site going
  16. cda
    cda Sawhorse
    Oct 19, 2009
    17,983
    1,253
    Talk to an electrician, there may be a little involved in moving it.
  17. James T Timler
    Feb 17, 2020
    15
    0
  18. James T Timler
    Feb 17, 2020
    15
    0
    Thanks for giving me the update tip. Here is a picture showing the cabinet where the electrical panel is located.
  19. James T Timler
    Feb 17, 2020
    15
    0
  20. ADAguy
    Sep 11, 2013
    4,552
    435
    ouch! not even in an exterior wall, is it fed from a crawl space?
Share This Page
