    Dismiss Notice
Electrical Panel Location
Discussion in 'Electrical Codes' started by James T Timler, Feb 17, 2020.
  1. James T Timler
    James T Timler Registered User
    Feb 17, 2020
    15
    0
    No crawl space under this house it is just on a slab. All wires appear to run in the ceiling and then back down along the fireplace and then into the panel.
  2. cda
    cda Sawhorse
    Oct 19, 2009
    17,946
    1,240
    Thanks for supporting
    Yea two more recruits and I get a toaster.
  3. cda
    cda Sawhorse
    Oct 19, 2009
    17,946
    1,240
    Have an electrician evaluate
    Maybe easiest is next to the fireplace.
    Where is the electric meter in relation to this picture.
  4. James T Timler
    Feb 17, 2020
    15
    0
    The meter is outside next to the chimney of the fireplace.
  5. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    10,658
    902
  6. ICE
    ICE Moderator
    8,870
    1,097
    Hello Mr. Timler,
    I noticed the glass doors on the fireplace. Here is a post that may be of interest to you. mtlogcabin is the member to look for.
    As to the electrical panel in the cabinet....well stuff happens. It's certainly not the best place for it. I can't imagine the owner being willing to move it for you. But who knows. Discovering something like that makes one question the rest of the electrical work.
  7. ICE
    ICE Moderator
    8,870
    1,097
    Not even. There's no disconnect and romex can't be exposed.
  8. Builder Bob
    Builder Bob Sawhorse
    Oct 17, 2009
    2,346
    368
    I figured it was up north with a black bear making coffee or cooking in the kitchen.
  9. cda
    cda Sawhorse
    Oct 19, 2009
    17,946
    1,240
    Darn modern codes
  10. ADAguy
    ADAguy Registered User
    Sep 11, 2013
    4,537
    433
    I had to back up for a moment, so you haven't bought it yet?
    Is the price right, have you had it inspected?
    Buying as is or will the seller negotiate or fix the non-compliant issues?
  11. James T Timler
    Feb 17, 2020
    15
    0
    We are just in the early stages. I was asked by a friend if I would like to look at it so I did. I really like the location and want to make this work. I believe we are in a "as is" scenario and I have not had an inspection done yet.
  12. e hilton
    e hilton Bronze Member
    Jul 2, 2014
    962
    214
    My 2 cents ... as-is is ok for worn carpet, cracked window glass, antique toilets. Serious stuff like the electrical panel fall into “must correct”.
    ADAguy likes this.
  13. James T Timler
    Feb 17, 2020
    15
    0
    Thanks, I believe I am going to have an general inspection and an electrical inspection. I will get a quote to fully understand what we are looking at. Thanks again and I really appreciate your advice
  14. cda
    cda Sawhorse
    Oct 19, 2009
    17,946
    1,240
    Is this your first house you have bought??
  15. James T Timler
    Feb 17, 2020
    15
    0
  16. jar546
    jar546 *****istrator
    7,645
    705
    I have one word to describe the panel location:
    Kindling
    VillageInspector likes this.
  17. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    2,432
    317
    Is the romex can't be exposed in a home a CA thing?
  18. ICE
    ICE Moderator
    8,870
    1,097
    This is from the CEC:
    334.15 Exposed Work. In exposed work, except as provided in 300.11(A), cable shall be installed as specified in 334.15(A) through (C).
    (A) To Follow Surface. Cable shall closely follow the surface of the building finish or of running boards.
    (B) Protection from Physical Damage. Cable shall be protected from physical damage where necessary by rigid metal
    conduit, intermediate metal conduit, electrical metallic tubing, Schedule 80 PVC conduit, Type RTRC marked with the
    suffix-XW, or other approved means.
    While I can't speak for all of California, my AHJ has determined that if the cable is exposed it is subject to physical damage.
  19. Norcal
    Norcal Registered User
    Aug 8, 2016
    51
    17
    Is there a disconnect at the meter? Or is it in the panel in the cabinet? The reason for the questions is to get a idea how long the unprotected service conductors are beyond the meter, if applicable.
    jar546 likes this.
Share This Page
