T
TZJR
Guest
Good morning everyone,
I need to confirm a question on an exit path set of egress doors, We need to shift the mid landing of a switch back ramp to the left because of a clearance issue at the top of the ramp. below you will see a pair of 36" doors exiting the building, from the back side of the ramp to the doors used to be 96" and i am reducing it to 74.25" to clear a path on the upper side. This is still larger than the 72" wide doors, does anyone see any issue i am missing (PA 2015 building code), ANSI A117.1 or 2010-ADA.
