steveray
The 50# is over a square foot.....Not a 4" sphere....
First lets start with a simple notation or should I say question.Frank said:I think I see a code change coming. This can also be an issue with cable type guards and barbed wire fences where one stepping on as if to climb, opens it for the other to crawl through. How flexible are the pickets? Are we talking 5 pounds push on the ball or 500? Proposed new language305.2.2 Openings.
Openings in the barrier shall not allow passage of a 4 inch (102 mm) diameter sphere with not more than 50 pounds of force applied in any direction.
The 50 pounds being in consistent with the guard strength requirement in the IBC
1607.8.1.2 Intermediate rails.
Intermediate rails (all those except the handrail), balusters and panel fillers shall be designed to resist a concentrated load of 50 pounds (0.22 kN) in accordance with Section 4.5.1 of ASCE 7.
I was with you 'til the last sentence. IRC Appdx. G105 is 4" sphere.tbz said:First lets start with a simple notation or should I say question.Were in the code is there load requirements for pool barriers?????????????????????????????????????????????????????????????
The loads that everyone seem to apply are for guards!!!!!!!!!!! Pool barriers have no load requirements and are only required to be engineered so they don't fall over when over 6ft.
Unless I am missing something.
Next, as to apply a force on the sphere, it seems people are forgetting that we allow 6" spheres it's about area not 4".
Sorry Mjesse,mjesse said:I was with you 'til the last sentence. IRC Appdx. G105 is 4" sphere.
Frank there is no key to requiring rigid in the code for pool barriers.Frank said:The key is how ridged are the members are
Agreed.tbz said:1.) inspector is only failing because the sphere passes through under force, IE: LOAD2.) inspector agrees that absent the load force barrier measures less than 4"
So IF OP information is correct the inspector is not correct with force on sphere.
ICE,ICE said:Rarely do I see a fence that's made of aluminum. So the inspector can fit the sphere through with force. How much force? Could a child generate that much force? Having not seen the test, I will defer to the inspector.
I have been wondering the same thing - ???mjesse said:Agreed.Now where did the OP go?
Frank was proposing new code language to cap the maximum amount of force one could apply to a sphere used to test the spacing. Basically, if more than the prescribed amount of force was used it is irrelevant if the sphere passes. As I posted earlier, with enough force you can get a 4" sphere to pass through any sized hole.tbz said:First lets start with a simple notation or should I say question.Were in the code is there load requirements for pool barriers?????????????????????????????????????????????????????????????
Is this already installed or is this plan review comment???danlawrence said:RE: FENCE POOL CODE INTERPRETATIONS – 4” SPHERETREASURE COAST, FLORIDA
A county inspector has failed an aluminum pool fence with 3 7/8” spacing between pickets. The fence is a commercial grade, 6’ high with (3) horizontals. (2) at the top and (1) at the bottom with ¾” pickets.
The code he is calling us out on is that the 4” sphere can be pushed (forced) through. The code reads “openings in barrier shall not allow passage of a 4” diameter sphere”.
I have installed thousands of fences over the last 25 years in business and have never had this issue.
Any feedback would be greatly appreciated.
Thank you.
Going to the 2012 IBCtbz said:Frank there is no key to requiring rigid in the code for pool barriers.I have yelled about it for years, it was suppose to be taken care of in the IIC pool code, I have not really read through it to see if it was covered, no time since no AHJ I work in has informed me that they are looking to add it and are looking for public comments. When it shows up I will.
But pool barriers have no load requirements in the model codes prior to 2015 that I am aware of, could be wrong on a local level, but haven't seen anything yet.
Styrofoam ball is wrong test tool, one is 1/16" small and two it is quite deformable on its own often used as padding on the inside of vehicles for impact mitigation.danlawrence said:Fence is already installed. Inspector came for the final inspection- took a ball that was 3 15/16" made of Styrofoam.Gently pushed it through the picket space, but could still hold the ball against the space without it going through if he wanted to.
Only when he pushed it through with minor effort, he said it will not pass code because code reads "a space that cannot be squeezed through"
We had a few similar products on the truck that he could do the same to, but when we turned the panels flat - the ball would not pass through any one of the spaces, unless he forced it. These panels were residential grade with 5/8" picket X 4' high, and he said "he would definitely fail ".
For references to products we mentioned - Ideal Aluminum , Jerrith Aluminum, Ameristar, Delgard, Elite. These are products we have used for years.
Consensus here seems to disagree with your local inspector.danlawrence said:Fence is already installed. Inspector came for the final inspection- took a ball that was 3 15/16" made of Styrofoam.Gently pushed it through the picket space, but could still hold the ball against the space without it going through if he wanted to.
Frank you are off with your quoting for the fence and the lack no loads you can apply guard loads. Been over turned in many a AHJ because the vast majority of fence does not meet those loading requirements nor are they even designed to meet loads near them.Frank said:Going to the 2012 IBC" 1604.2 Strength.
Buildings and other structures, and parts thereof, shall be designed and constructed to support safely the factored loads in load combinations defined in this code without exceeding the appropriate strength limit states for the materials of construction. Alternatively, buildings and other structures, and parts thereof, shall be designed and constructed to support safely the nominal loads in load combinations defined in this code without exceeding the appropriate specified allowable stresses for the materials of construction.
Loads and forces for occupancies or uses not covered in this chapter shall be subject to the approval of the building official.
1604.4 Analysis.
Load effects on structural members and their connections shall be determined by methods of structural analysis that take into account equilibrium, general stability, geometric compatibility and both short- and long-term material properties.
Members that tend to accumulate residual deformations under repeated service loads shall have included in their analysis the added eccentricities expected to occur during their service life.
Any system or method of construction to be used shall be based on a rational analysis in accordance with well-established principles of mechanics. Such analysis shall result in a system that provides a complete load path capable of transferring loads from their point of origin to the load-resisting elements.
Every structure shall be designed to resist the overturning effects caused by the lateral forces specified in this chapter. See Section 1609 for wind loads, Section 1610 for lateral soil loads and Section 1613 for earthquake loads.
1607.2 Loads not specified.
For occupancies or uses not designated in Table 1607.1, the live load shall be determined in accordance with a method approved by the building official. "
If the loading is not specified it does not go to zero. While a pool barrier is not included in the definition of a guard that is what is most resembles in function and therefore the guard requirements are appropriate for structural loading of pool barriers.
thanks for the additional information Dan, are you able to provide us with the exact code section wording. I have never seen a sphere requirement code wording that says "a space that cannot be squeezed through" that is about the worst code language there can be, because all spaces can be squeezed through.danlawrence said:Only when he pushed it through with minor effort, he said it will not pass code because code reads "a space that cannot be squeezed through"
This has been an issue for me once. It was a guard around an atrium at several floor levels. The posts were 2" re-bar and there was cable strung between them. I use a tape measure and fingers. If I push on the cable and it moves, there may be a problem. It has been a while since the cable guard but as I recall, they had to double up the number of cables.Fence is already installed. Inspector came for the final inspection- took a ball that was 3 15/16" made of Styrofoam.Gently pushed it through the picket space, but could still hold the ball against the space without it going through if he wanted to.
""""Fence is already installed. Inspector came for the final inspection- took a ball that was 3 15/16" made of Styrofoam."""ICE said:This has been an issue for me once. It was a guard around an atrium at several floor levels. The posts were 2" rebar and there was cable strung between them. I use a tape measure and fingers. If I push on the cable and it moves, there may be a problem. It has been a while since the cable guard but as I recall, they had to double up the number of cables. So what's that got to do with this post about an aluminum guard. Shirley not a lot.
You say there are 3/4" pickets. 3/4"x what? Give us a picture. You know, there is usually more to the story. You've been building fences for 25 years....... certainly you have 4" balls. You did say that the inspector is gentle so if you break out your set he probably won"t bust your balls.
