"The gas pipe has been stubbed out. Something is installed.
Would you then, allow a toilet rough-in to be installed in a compartment that is way to narrow to accomodate the required side clearances? since it's only a rough in.
If someone wants to rough in for a toilet, sink, and shower for a "future" bathroom, we would require them to also rough in the exhaust fan. Am I wrong to do this?
Very similar to what is being discussed."
Nothing is installed other than a gas stub that may or may not ever be used.
Rough-ins are just that, for a POSSIBLE future installation. We have almost always full basements in this part of the country, there are always bath rough-ins included. No, I don't try to figure out how it will be arranged, because most likely it will get moved before it is all said and done. And no, we don't require a fan be roughed in.
We see sometimes see A/C linesets roughed in for future use. Should we require the coil be installed, the electrical stubbed out outside, the base set? No, not here. Rough-ins are a convienient option for possible future use.
Heck if I used that theory, I would have to have them finish the basement immediately when it was installed, because if its there, I must assume they will use it in some fashion, and not get a permit to do it correctly. NOT.
JMHO
