R101.3 Intent.But as far as inserting it into the code, why wouldn't we want it inserted into the code for say pre hung interior doors to compartmentalize the fire.
You may want to revisit your hypotheses once you see tests in actual conditions, real life houses/apartments.Getty said:Well knowing first hand being a NYC firefighter the temperature at the ceiling level is waaaayyyyyyy above the temperature of the fuseable link which is set right now at 137 degrees. From what I understand about the old fuseable links ( and I am by no means an expert) is that they were set at a much higher temperature and were further down on the door. We did do our own tests in a fire in Long Island and the hinge performed as designed. We do need independent testing. To answer the smoke question which we have encountered a lot. The fire plumes up to the ceiling spreading along the ceiling till reaching maximum width then starts down. The space between the ceiling and the top of the door would be filled before smoke could enter the room by the time that smoke is low enough to enter the room the ambient heat and radiant heat would trip the fuseable link before the smoke could enter the room. If the ceiling temperature is 1000+ degrees 1 1/12 feet down would be well over 300 degrees to trip the link.
Cda yes our vision is to have this on all interior doors in a house or apartment to compartmentalize the fire. I do understand your disdain for fuseable links however it seems a lot of people have the same problem. The video I saw was stages of a fire. But as I said I have been in hundreds of fires if I pulled up to a compartmentalized fire as opposed to a fully involved structure the difference is night and day. May I ask your occupation so I can embarrass myself some more lol. The thought we have is that most new construction have pre hung doors installed if the pre hangs came with these hinges that would be a way to accomplish the initial phase then once that success is realized it will expand into retrofitting existing interior doors. Please tell me besides your disdain for fuseable links why this is a bad product or why it won't work or some other thing that I am not seeing. We really do want this product to save civilian and firefighters lives and we want to get it right so any feedback is positive for us. Thank you in advance.steveray said:I give FB's IT a DUD....I have doubts that the hinges will actually work, but it is a good idea.....
firefighter long time agoGetty said:Cda yes our vision is to have this on all interior doors in a house or apartment to compartmentalize the fire. I do understand your disdain for fuseable links however it seems a lot of people have the same problem. The video I saw was stages of a fire. But as I said I have been in hundreds of fires if I pulled up to a compartmentalized fire as opposed to a fully involved structure the difference is night and day. May I ask your occupation so I can embarrass myself some more lol. The thought we have is that most new construction have pre hung doors installed if the pre hangs came with these hinges that would be a way to accomplish the initial phase then once that success is realized it will expand into retrofitting existing interior doors. Please tell me besides your disdain for fuseable links why this is a bad product or why it won't work or some other thing that I am not seeing. We really do want this product to save civilian and firefighters lives and we want to get it right so any feedback is positive for us. Thank you in advance.
Shoot your proposal to Dan M. See if he will give you a one paragraph opinion on it.Getty said:I hope you return cda to help me and answer some of my questions. Thanks again for the questions
