rnapier
Silver Member
Except for the fact that water suppresion is not addressed in the IFC or IBC 904, is there any reason why water could not be used as the suppressing agent since grease is not the factor but type of fuel is?
cda I do not see where a hood is required, the manufacturer has designed the oven to be direct vented. If you start with IMC section 917 it tells you to look for UL 2162, that document Commercial Wood Fired Baking Ovens Refractory Sends you to NFPA 96 Standards for Ventilation Control. Chapter 14 Solid Fuel Cooking Operation.cda said:Still trying to find a vent a hood to fit this wood oven
What I am referring to is the pizza oven needs a hood because of the fuel source. A pizza oven is not considered a grease producing appliance per IMC.north star said:= o =rnapier,
Respectfully asking, ...but why would grease not be considered as part
of the propagating fuel source?
Solid fuel, "yes", ...but I'm thinking grease deposits on the interior
of the masonry, from all of the previous pizzas, will require a
compliant type of suppression system.
cda,
The pictured oven will [ typically ] require a custom built hood!
= o =
Operating temps for wood fired pizza ovens vary according to the style of cooking. Typical floor temps will range from 550 - 750.lunatick said:Wood Stove Equipment/Appliance that have been posted here. Any indication at what temperature they are operating at?The instruction/manual sheets I have seen referenced do not indicated the operating temperature.
The traditional Napoli ovens of the pizzeria I go to operate at 800F.
With no door on the front, there is a constant draft exhausting the cooking exhaust out through its flue. Like a traditional fire place.
But I suspect the appliance you have depicted here are not operating in the same manner.
Gregg, I agree. To add more to it:Gregg Harris said:cda I do not see where a hood is required, the manufacturer has designed the oven to be direct vented. If you start with IMC section 917 it tells you to look for UL 2162, that document Commercial Wood Fired Baking Ovens Refractory Sends you to NFPA 96 Standards for Ventilation Control. Chapter 14 Solid Fuel Cooking Operation.14.1.1 Where solid fuel cooking equipment is required by the manufacturer to have a natural draft the vent shall comply with 14.4
14.4 sends you to Chapter 7 for installation type depending on building elevation.
Thank you. Currently I am consulting but have worked for a wood fired oven company for over a decade. My responsibilities included bringing products to market which meant going through the UL testing. I have found this forum helpful so rather than stand at the side and watch the confusion I thought I would join and offer what I can.cda said:Welcome mugDo you mind stating what you do for a living
Good to have you here and participating. Welcome!Mugman said:Thank you. Currently I am consulting but have worked for a wood fired oven company for over a decade. My responsibilities included bringing products to market which meant going through the UL testing. I have found this forum helpful so rather than stand at the side and watch the confusion I thought I would join and offer what I can.
I have never had wood fired pizza and hear that it is very good. Dinning options here are pretty limited.JPohling said:Mugman! You must have been successful because every time I turn around there is a new wood fired pizza place in San Diego!
Was in SD for Easter mom brother sister live thereMugman said:Thank you. Currently I am consulting but have worked for a wood fired oven company for over a decade. My responsibilities included bringing products to market which meant going through the UL testing. I have found this forum helpful so rather than stand at the side and watch the confusion I thought I would join and offer what I can.
