conarb
Re: I don't like I-joists either.
They are not in the prescriptive code so far as I know, as such if they are used, or where they are used, is none of the inspectors' business. I seems to me that if they are used the AHJ should require engineered designs. Industrial hygienists are finding extremely high levels of formaldehyde and other chemicals in new homes, and engineered wood products are the prime suspects, if you recall several years ago a family was sick from the offgassing of I Joists and it was determined that it was from the open cold air returns running through them, the solution was to duct the cold air returns in homes with I Joists, but the carcinogenic fumes are still there. Elmhurst Illinois has the best solution, in homes with I Joists they require fire sprinklers, to date nobody has installed I joists because nobody wants the expense or liability of fire sprinklers.
M & M:M & M said:Conarb,An inspector that does not know where the squash blocks go should find a different job.
