tbz
Rick,
Here in lies the question, the fact it is an alteration and that they have initiated a handicap parking space by installing the sign in the first place, if the sign was not there, then I would agree. However, since the property has a sign, the intent was from the property owner to provide the handicap parking space, its not your fault it was not installed correctly, the sign is there in place for the unknowing to use as noted.
Not sure you can make them fix the actual parking spot, but from where I sit there needs to be a route to the designated spot simply because the sign is there.
Definition or not
That is the way I see it, and remember that Feds passed ADA in 92, so any work done after that even if PA did not have codes for that area unit after 2004 there still was a requirement they did not follow that you don't have jurisdiction over, unless the area was built prior to 1992.
Definition or not
