Papio Bldg Dept
As jar noted, this maybe more state, or locally, driven. If it is a big deal to you, then you may want to re-present your case to the BO. As for it not communicating with the rest of the house, I tend to disagree with your assessment of comparing it to a garage. Your OP space is communicating with the upper levels, even though there is no stair case. Your mechanical appliances are creating penetrations and these communicate with the upper levels. We have plenty of unfinished basements on our NSFR permit applications, and we still require a smoke alarm to be interconnected. If these spaces were seen as a garage, we would eliminate the smoke alarm requirement, but require 1/2 GB at the walls, and 5/8 type x at the ceiling, not to mention the protection and raising of gas appliances. I don't think you really want to look at this as garage comparison with living space above. Would you then install dampers between for the 1 hour separation required? Would you assign a listed penetration assembly for your water and vent lines?Dennis said:Since the area is not adjacent to bedrooms we do not need to install a co detector. I was just bring up the NC rule. It is interesting that every building inspector seems to agree this is a basement even though it is unheated and there is no communication, however if I asked if it were a shed built attached to the house with separate entrance no one thinks it would need smoke detectors. I still don't see the difference and on second thought they tend to agree.BTW- all electrical contractors are surprised it was needed. Of course it is a building code.
In your assessment, what is the likely hood the homeowner will store gardening and lawn supplies, or other home repair items (i.e., paint and rags/brushes) in this non-basement? If a fire starts here, what is to protect, or at the very least, warn the occupants in the floors above? In my perspective, it is a reasonable request, and at the minimum, is not something I find surprising.
Of course it is not an electrical code. Electrical code doesn't say you can't put your lights behind a GFI outlet in a basement...but usually common sense prevails. Not sure I would want to be using a skill saw in my unfinished basement and have the lights go out when the GFI trips.
