Glennman,Glennman CBO said:301.3 All plumbing fixtures used to receive or discharge liquid wastes shall be directly connected to the sanitary drainage system of the building in accordance with the requirements of this code.A faucet does not discharge wastes. A drain discharges wastes.
A kitchen range is not an "other surface" (prevention of damage to walls, and other surfaces through fixture usage). Besides, ranges that I have seen can get wet without damage.
Water spouts on refrigerators do not have drains.
Plumbing shall be installed with due regard to preservation of the strength of structural members and prevention of damage to walls, and other surfaces through fixture usage.
It is the damage to structural members, walls and other surfaces (like cabinets) that surround the range that fixture usage is required for; not the range top. The range top does not qualify as a plumbing fixture.
So you would approve the following installations? If not why?
1. Bar countertop in living room. A wall hung faucet is installed over the countertop; and there is no sink (fixture). Also a non-GFCI electrical receptacle is installed within one foot of the faucet.
2. Laundry room. A cabinet with a countertop is installed in the laundry room across from the washer and dryer. A wall hung faucet is installed over the countertop; and there is no sink (fixture). Also a non-GFCI electrical receptacle is installed within one foot of the faucet.
They are just as code compliant as installing a pot-filler faucet over a range. The code intent of requiring a fixture for the faucet should be clear.
