wwhitney
If I understand correctly, there's a distinction between (a) the particular spatial volume that is required to be clear of obstacles and (b) whatever possibly larger spatial volume may in fact be clear of obstacles in a given compliant installation. I would assume that in discussing this topic, the terms "knee space" and "toe space" would default to meaning (a), rather than (b).I'm amazed that the Access Board says the 6:1 slope never changes, because obviously it CAN change. It can be perfectly vertical, in fact. And, going the other way, the 6" horizontal toe space is a maximum dimension. Leave everything else unchanged and reduce that to 3 inches. Still compliant, but the 6:1 slope is no longer 6:1.
So in the sense of (a), are there rules/conditions that would result in the changes you describe above? Or are you just referring to the sense of (b)?
Cheers, Wayne
