An average day
I'm not familiar with those post bases. Is there supposed to be that space below them?
I've never seen someone try to block up a column with plywood...
Stand off post base, no the concrete is required.
The contractor went to the office to complain about me. He demanded a code section for each correction. The job is just one room and he only got eleven corrections so I don't understand why he is so upset.
Shim shiminy, Shim shiminy, Shim shiminy, Shimroo..... I would have to look at door manufacturer instructions on that....Most of the Simpson post bases do have a set distance to edge of pier, very rarely do the contractors know that...
Post # 2446
That's a real "pickle" can't find a solution with any Simpson products, they require additional side cover or more base, looks like a job for "super engineer!"
Post # 2446
The correction notice said to provide an engineered fix. A lady came to the counter and asked me how I want her to fix the problem. She was quick to point out that the hardware is called out on the plans....."so if you guys missed something here".....it's causing Harshness to be unleashed.
tmurray, could you post that part of your code, I like to see how that's worded?
There's a limit to the height a stud can be, table R602.3.1.
9.23.10.4. Continuity of Studs
1) Wall studs shall be continuous for the full storey height except at openings
and shall not be spliced except by fingerjoining with a structural adhesive. (See
Note A-9.23.10.4.(1).)
A-9.23.1 0.4.(1) Fingerjoined Lumber. NLGA 2014, "Standard Grading Rules for Canadian Lumber,"
referenced in Article 9.3.2.1., refers to two special product standards, SPS-1, "Fingerjoined Structural Lumber,"
and SPS-3, "Fingerjoined "Vertical Stud Use Only" Lumber," produced by NLGA. Material identified as
conforming to these standards is considered to meet the requirements in this Sentence for joining with a
structural adhesive. Lumber fingerjoined in accordance with SPS-3 should be used as a vertical end-loaded
member in compression only, where sustained bending or tension-loading conditions are not present, and
where the moisture content of the wood will not exceed 19%. Fingerjoined lumber may not be visually
regraded or remanufactured into a higher stress grade even if the quality of the lumber containing fingerjoints
would otherwise warrant such regrading.
From the intent statement:
Intent 1:
To limit the probability of discontinuity, which could lead to member instability, which could lead to an inability to resist expected gravity or lateral loads, which could lead to excessive deflection or failure.
This is to limit the probability of compromised structural integrity, which could lead to:
  • the structural collapse of wood-frame construction, or
  • where wood-frame construction supports or is part of an environmental separator, the excessive deformation, displacement or failure of required environmental separation elements, which could lead to deterioration, which could lead to further compromised structural integrity.
This is to limit the probability of harm to persons.
Intent 1:
The wall in the picture is not a bearing wall so the hinge is not a concern.
Why are all the pipes running down into the slab and looping right back up? Did somebody think that they're what is bracing the wall?
Protecting that copper from the concrete I suspect.
Is that a building sewer 10-ft head of water test for 15 minutes?
I've done 4 of those in another city and three failed, that's a PITA, always gotta go back!
I'm not sure my legs didn't run the pipes from point-to-point inside the wall but I'm sure those loops are so they don't have to have any joints in the piping under the floor. It certainly would have been easier to just come up once and then run through the wall. Another option which is used quite often is to run home runs for each point of use from a central manifold. It takes more pipe but offers several advantages.
Dead and live loads aren't the problem. It is the wind and seismic loads. The wall will have a tendency to fold at the hinge with wind or seismic.
Some would say that the wall is a bearing wall by default because it is an exterior wall. The ceiling is vaulted. The wall above the top plate is 8” tall at the left end and 28” tall at the right. The rafters and joists run parallel to the wall. Balloon framing would have been stronger.....
