MtnArch
I know, Mark! Just tryin' to make a funny!!Not Simpson, hot and cold water plastic sleeves for embedded pipe
(yup ... would starve as a stand-up comic!)
Some would say that the wall is a bearing wall by default because it is an exterior wall. The ceiling is vaulted. The wall above the top plate is 8” tall at the left end and 28” tall at the right. The rafters and joists run parallel to the wall. Balloon framing would have been stronger.....
This doesn't happen often.
As far as I know, we have never allowed wet setting anchors.
I spent twenty minute this morning looking for a code for that. I didn't find it in the Residential Code or the Building Code. Oh well....I'll pencil it in.Interesting.
SECTION R506I spent twenty minute this morning looking for a code for that. I didn't find it in the Residential Code or the Building Code. Oh well....I'll pencil it in.
Nothing in the code but this is from the webThanks for that Mark. How about a code for the anchor bolts and wet setting.
Mark Handler said:Most Engineers, as well as most Building Officials, have seen the voids often left to one side or the other of a “wet set” bolt or dowel or strap – sometimes obviously reducing it’s structural capacity and increasing liability to the Engineer, Building Official, Owner and Contractor. When embedded dowels, bolts and straps are “wet set” we would recommend that a randomly selected portion of these embedded hardware are pull tested to full rated capacity prior to acceptance by the Engineer or Building Official.
