what about the can of deodorant spray, I suppose that can't be on the lid either...Nuts!
The controls on the can would have to comply with ADA controls requirements........HAH !
If attached to the floor how far does it project out from the face of the wall? Appears to be an obstruction.
ICC A117.1Toilet has a automatic flusher. The problem is the code allows shelving in the water closet clear space but has no limit in how large or where it is. They could even put shelving between the toilet and wall. When I fail inspection I am required to state a code section and there is nothing I can use for this.
ICC A117.1
604.3.3 Clearance Overlap. The required clearance around the water closet shall be permitted to overlap the water closet, associated grab bars, paper dispensers, sanitary napkin receptacles, coat hooks, shelves, accessible routes, clear floor space at other fixtures and the turning space.
No other fixtures or obstructions shall be within the required water closet clearance
I posted that because Rick18071 needed a cite number to use.That is what I am saying. There is no limit on how much the shelves take up of if they need to be mounted to the wall.
