That pic makes no sense to me whatsoever as there is probably a rod missing and trying to figure out the purpose of the conduit and romex connectors on the ends of the threaded coupler and why the rod is not all the way in the ground (if it is 8'). Expensive clamp, however.
Wrong size cover plate.Why you need to remove the bottom drawer of the range during final inspection: what violation would this be?
That or aesthetics.I am just going to assume that the purpose of the conduit is the reduction of copper theft?
The carpenter says incorrect connector?
I checked the website for State Water Heaters, looked at a random installation guide for a residential electric heater. It says (paraphrase) install the electric service in compliance with local codes. Follow nfpa 70 and nec if no local codes. In stall wiring in an approved conduit if required by local code.Find a water heater such as this one that specifies a flexible cord that can be used with it.
That is a 125/250V rated dryer cord, non-grounding, the use of a flat cord is hokey at best, but the water heater being cord & plug connected is not kosher made worse by the plug being mounted upside down, noted by the way the right angle plug is hanging. A bad install all around.
please provide the section number in the NEC that requires the respectable to be in a certain direction.
I suspect you are right, but some inspectors demand the ground prong be up.I believe it is his opinion that it is a bad install method and not a code issue.
