The topping slab is 7" thick.
The existing pipe is tight to the wall.Looks like a shortage of insulation. Or they insulated the new piping, not the existing. Strange.
Ok. So ... does calif code require insulation on piping and a thermal jacket on the WH? If yes, does it exempt piping against a wall?The existing pipe is tight to the wall.
I just had the exact same Rheem water heater installed, the pressure relief valve is inside that black insulation to the right of the Rheem emblem,Where is the Temperature Pressure Relief pipe?
"New" code only applies to "new" stuff correct?
R102.7.1 Additions, alterations or repairs. Additions,
alterations or repairs to any structure shall conform to the
requirements for a new structure without requiring the
existing structure to comply with the requirements of this
code, unless otherwise stated. Additions, alterations,
repairs and relocations shall not cause an existing structure
to become unsafe or adversely affect the performance of
the building.
The vent is the existing transite.....and you are right about the "no support". One down, three to go.If I am not mistaken it looks like the vent is PVC and nothing is supporting it.
That was going to be my question. I was pretty sure it was transite from the pic. Darn heavy not to have any support, surprised the pipe collar is holding it.he vent is the existing transite.
"Son, we live in a world that has codes, and those codes have to be guarded by men like ICE, who's gonna do it? You want ICE on that code, you need ICE on that code!!"
Something like that!
