So any info on who wrote this? Colleague?
Nope, it's meant just like it reads.I have a feeling he was trying to write "connections" and wrote "conduits" maybe.......
Did he buy them from Walmart? Or angies list?This person has 30 ICC certifications.
Actually your word switch makes more sense.Agree with JP!
Should probably re-write the report and switch the "be" and the "not", then it would make since?
There is no separation required between ABS sewer and any water pipe of any material. There is no separation required between gas pipe and sewer or water pipes. DWV is inside the building.
If clay sewer were involved the code is not "18” below water pipe."
Not at all. Just unnecessary digging. I wondered about the code if it is clay sewer pipe. The clay would have to fail and also the water pipe. Then there would have to be a loss of pressure in the water pipe.Good practice, no? to prevent potential cross connections by leaking sewer pipes.
Plumbing ... electrical ... it’s all pipes.The job is an ADU. As it turns out, the plumber was also the electrician...was
Speaking of plumbing.....the water heater is ready for inspection.
