AgreedThey still need to be anchored down
That's very reasonable. 4" slab and anchors. Do you require any base under slab? Not sure if that contributes to safety but should prolong useful life of slab.Agreed
We amended the shed exemption to require "all sheds require a permit and inspection". A fee is collected based off the sheds valuation. Sheds have to be anchored here, but there are some in our boundaries that are not permitted.
We allow <120sf to be on runners and earth anchored.
<300sf to be on a 4-inch minimum slab with anchor bolts and rebar.
>300sf require footings.
3/4-inch clean gravel base, rebar or wire mesh, L-bolts or approved drilled anchors.That's very reasonable. 4" slab and anchors. Do you require any base under slab? Not sure if that contributes to safety but should prolong useful life of slab.
I assume earth is augur. Any guide on quantity, diameter, depth? Or just accept the basic 4 pack?
These items are not regulated by the codes here.What about garbage cans, dumpsters, play ground structures? required to be anchored? so many things, like clothing collection boxes.
It was entertaining, in its way...I think Evil picked up his toys and left the room.
I'm generally saddened by the increasing lack of civility in discussion.It was entertaining, in its way...
Yeah and the phrases "pot calling the kettle" and people in glass houses" kept coming to mind. It was like someone walking into to a room of professional athletes, well professional anything, and getting upset that they won't help them become a pro overnight.I'm generally saddened by the increasing lack of civility in discussion.
Yup and yup. Did you notice how many times he said "teeny tiny little shed"?Anyone else immediately feel on edge when you work with someone and the first thing they do is give you their resume?
Generally speaking, as soon as someone starts telling me all that they know and how much experience they have, I start to assume that they won't listen and are going to give every excuse under the sun.
He wore out his wecome.And Evil dropped out after #40...................![]()
