Mr. Inspector
Jar. If they are repaving a parking lot on a slope, if you would call it an alteration, would you be against them doing something else to spend the 20% on like new accessible drinking fountains?
Stripe the gravel...Not my problem....Most of the parking lots in my area are gravel or just dirt with no painted lines. If they add more gravel or dirt and the building was built before we had codes (2004) and no accessible route or accessible anything in them, which most are like in my area, would you make them put in an accessible parking space?
If neither the Certificate of Occupancy nor the approved plans show a minimum required number of parking stalls,Most of the parking lots in my area are gravel or just dirt with no painted lines. If they add more gravel or dirt and the building was built before we had codes (2004) and no accessible route or accessible anything in them, which most are like in my area, would you make them put in an accessible parking space?
Striping the gravel is just a tease, because it implies that gravel is intended to be accessible, which is unlikely given the irregular surface.Stripe the gravel...Not my problem....
1106.2 Required
Where parking is provided, accessible parking spaces shall be provided in compliance with Table 1106.2, except as required by Sections 1106.3 through 1106.5.
The issue there is when you get them in and there is no place to go to the bathroom it gets messy....Literally...The places I have worked would require the actually accessible spaces/ramps/sidewalk to the door to be either paved or concrete & meet slope requirements. the rest of the parking lot could be left gravel. And generally no on spending the 20% somewhere else. The agreement on that is you must be able to get in the building first before doors/drinking fountains/POT/accessible stalls etc. are needed.
The debate over doing the entrance or bathroom first when it comes to accessible upgrades....Steve, only the disabled need to use the restroom?
I agree that in a "real world", bathrooms are a higher priority in parking. However, I've had at least 2 alteration projects in a major so Cal city where it was the position of the building official that "accessible route" priority #2 included an exterior route to the parking access aisle, but did not include the parking stall itself.Accessible parking is way down at #6. No exterior accessible route until then.
Having an accessible bathroom without an accessible entrance to get to the bathroom is pointless.
