jdfruit
You want code sections? give me your code book & C10 contractor's ID pocket card. OH, you don't have either, well when you do, let's talk. (paraphrasing someone else's snarky post on another thread)
You might be right but it looks sorta like a rivet. The one on the right is barely visible and looks like it is the same diameter. I asked them to start over with a service upgrade. They complain a lot so I'll probably have to return before they do the work. If so I'll get a better picture.jdfruit said:starting with 1975 NEC, min 100A for service equipment on new single family homes. Double check the meter feed bar (insulated) to buss bars; looks like the connector machine screw is missing the head.
It is possible. I'll look for one. There's about a bunch of wrong crimps on this job and at some point they will be done correctly...I can get a picture of that.MASSDRIVER said:Do you have a pic of a properly crimped connection?Brent.
Pcinspector1 said:"Condenser needing inspected"? Maybe the contractors next door, getting a massage?I didn't run into him.
Wouldn't you know, I didn't write that correction when I was there. I saw it in the picture and had to call the contractor. Thankfully they had gone for the day and I left a message. They have another request in for today.Pcinspector1 said:post #1341, looks like the wall cavity is open to the attic lacking a fire stop
