How can you tell the step rise is wrong? Other than the first one.
That's a
"may" disclaimer, cuz I can't tell for sure, but it does look like the bottom and the top risers are a bit different from the main run risers. IMO, they look higher than 7-3/4-inches to me? Could be wrong.
I think more deck builders have issues with stairs than anything else on the deck project, would anybody agree with that? For instance the handrail between (34-38-inches), I'm lucky to even get a handrail, usually I get a flat 2x6, and the framer sez, "That is the handrail, so and so city allows that!" Man your being a D...Debbie Downer!
Now lets say the deck dude makes a new set of stairs, and meets 90 percent of the code requirements. I'll almost guarantee the handrail will be out of the (34-38-inch) range because they will not have the stair guardrail high enough for the handrail and bracket which will put the handrail in conflict with that 2x6 top cap. I have seen a handrail bracket used upside down trying to be compliant. After you have done two final deck inspections with corrections, the percentage of compliance and the final inspection becomes harder to achieve. So I think some items are overlooked by inspectors to get that final inspection over with.
Also you better go up and check the decking screws, I had a crew put one screw through the decking into each FJ in a "W" pattern and claim they have less decking issues, "come on dude!" Now I got to come back and re-inspect to make sure the homeowner is getting what they paid for! Same crew left the vinyl siding off, said they don't do vinyl siding work!
I can't give enough information out to get a compliant deck unless it's a professional deck builder. It starts with a poorly filled out application and no plans submitted, then it morphs into guiding the applicant to a building supplier for some free plans. I'm at the point that I would like to have only two or three decks plans designed with material list including install instructions stamped by a RDP that we will allow unless the applicant brings in a deck plan designed by a RDP. But then there's the stairs and the different deck heights that screws that idea up..
Jar, Thanks for the pics! I'm sure you have more.
