Oh Well
The plate is 3"x6"...if that helps
ICE said:Do you approve these wire insulation stays?
Obviously the instructions aren't getting through to this contractorDue to high temperatures, the appliance should be located out of traffic and away from furniture and draperies.Children and adults should be alerted to the hazards of high surface temperature and should stay away to avoid burns or clothing ignition.
Young children should be carefully supervised when they are in the same room as the appliance.
Then how ARE roofs checked? In Houston, on commercial roofs, there is a certification (I believe it is a statewide cert) for roof inspector. I've talked with some of the inspectors from testing labs, it's not an easy cert to get, a fair amount of classroom time, I believe there might be some on-the-job time required and a test. I'm toying with the idea of getting it, just to have another feather in my cap.pyrguy said:Was fall protection, ladders, and other safety equipment on the site for the inspector's use? Just twisting tails. Our inspectors are usually not allowed on roofs due to liability issues. Both from a fall or damage to the clay tile roof which is the norm here.
