An average day
It's embarrassing when concrete puddles at your feet. Especially when you want it to be a stem wall.
Ask me how I know.
Brent.
ICE said:
7Detail #9 has two sections. A PLAN and B DETAIL.
How can you blame the grunts in the field? The plan view shows an 18x18x 12" thk footing, but the detail shows the footing min 26" thick. Archy screwed up.
ICE said:
7I wrote a correction to raise the vent two feet above the adjacent roof. I wasn't sure if two feet is the right number....I still don't know.
Except that the horizontal run of pipe is not sloped, I commend their solution. Not only is the pipe higher than the adjacent roof like The Man asked for, but it's also well supported.
It's about 85 bucks of home depot crap.
There is no defending that, so please don't.
Brent.
Actually, the support is not good at all. A gravity vent is not allowed to have more than one 60 degree bend and the rest at 45 degrees. There is no need for any bends.
MASSDRIVER said:
It's about 85 bucks of home depot crap. There is no defending that, so please don't.
Brent.
Oh, so now you are concerned with cost? When did that become part of your domain?
MASSDRIVER said:
You have to know boilerplate when you see it. Everyone I drink with knows it's details first, plan second.
Brent.
Then you're drinking with the wrong crowd. The overall plan should come first, then the appropriate details are selected to suit the conditions. That's how the archy earns his fee.
I did not know those details, so i CONCEDE. hOWEVER, i SUSPECT THE INSTALLER WAS CONCERNED THAT RAISING THE PIPE AS HIGH AS YOU WANTED, USING THE SKILLS AND MATERIALS AT HIS DISPOSAL, THE (damn caps lock. sorry) pipe was going to be unsupported. He's wrong, but he did try to make the installation sturdy.
Oh $h!t kid, he's a plumber. He doesn't know anything about sturdy. It's not sturdy. It is flimsy. And beyond ugly.
Before I hear that ugly is not in the code....I know that and that's what I told the owner....ugly is up to him and he has a right to get a not ugly job.
The job is a service upgrade done by a past owner. The new owner took out a permit.
Notice that the hinge pins are missing.
The pins are missing because the door will not swing open. It takes a hammer.
Really? That's your reply?
Well, I'm a magnanimous bastard and will give you another try. So try harder.
Brent.
You are 180 degrees out of phase friend. You bore down into detail sheets to EXPLAIN the overall plans. Otherwise you would not know about specific connections or dimensions.
Plans say "shear wall 2". You go to the details and schedules to find out what that is, nailing, spacing, frame component size, anchoring hardware specs.
I'm not calling you dumb, but if that is the way you read plans, you should find a mentor or something. Details before plans resolution is basic and industry wide. That's not even arguable.
Brent.
There is a misalignment going on here. Doesn't look all that bad.
I used my bionic arm to take the picture.
Until you see the big picture. It is 6" pipe so the plumber told me it was no big deal because the pipe will never be under pressure. I can't leak if there's no pressure he says.
I told him that I was putting him under pressure because I want to see a CAL-OSHA trench permit.
Does anybody care about being dead in a trench?
I don't know the stats on how many people suffocate in a trench cave-in every year but it happens too often in SoCal.
That is the topic that started this thread. Damn, I've been yammering on for better than two years and it all looks the same.
Apparently we are speaking different languages, I can't believe you and I are this far out of phase. Here's what I'm talking about, with regard to the design of the project. the archy starts with the overall concept, starts with the basic floor plan on sheet A-1 and then the elevations on sheet A-2, then goes into the details. Somewhere along the way there is a foundation sheet that is based on the architectural floor plan, and as part of the foundation plan the archy selects the correct details from his cad files of details and pastes them on the sheet. I really doubt that the archy (or engineer) says "I think on this job i will use a bunch of S-3 footings, I wonder what kind of building I can put over them". The details are a very important and integral part of the design, it's what separates a professional set of plans from the house plans you can order from the back of Southern Living magazine.
The drawing that got you guys to talking was a plan in a can. That is evidenced by the conflicting information. Had the reference to the details found on the foundation plan said 9/SD5(A) or (B) there would most likely not been such a mistake. There's always a bunch of details that don't apply. I've had single story buildings with full on elevator details.
I used to plan check...and I asked that all the BS sizzle be replaced with steak.
I will point to a neighbors house and say, "There you are Sir, that's what it is supposed to look like."
That didn't work today.
The person that did this was suckered into building a tiny room addition on piece work by a contractor that doesn't give a rats :butt what it looks like. The entire mess is 225 sq ft. and I have been there 15 times....with another six to come. It is a bedroom extension, bathroom and walk-in closet. I have written 29 corrections. Most of the time, the work isn't ready, yet it was ten days since the corrections were written. It took four attempts to get the windows flashed correctly even though I explained it in detail each time.
The guy knows nearly nothing about construction.....but he does know how to complain to the office manager. That started when I made him remove the work from the top plates up. Why my office manager pays any attention to this idiot is beyond me.
The midget is in his early twenties....English is a second language and every eighth word is discernible....He has crude tattoos and calls me Boss....I have been expecting to hear "Permission to pee Boss"....He has an abundance of attitude and knows his rights. He thinks that one of his rights is to have me reprimanded and replaced.
The office manager listens to him shout what an expert builder he is. Then I hear "I'll make sure that you get the first inspection tomorrow/ yada yada yada. I expect the manager to tell him that he's an idiot and get the Hell out of my office. When I suggest such a reply, I'm told that any complaint from anyone must be treated like all other complaints. In other words we must take them all seriously and treat all complainants with the utmost respect.
What a bunch of crap that is.
The idiot needs to be told that he's an idiot. How else is it going to get through to him that he's an idiot. Legitimizing his complaint takes legitimacy away from a legitimate complaint.
We will be these people soon enough http://www.wimp.com/indiapakistan/
Do you see a fatal flaw?
Does this help you?
The valleys were created by an addition done long ago. I wrote a correction to install crickets. Within an hour I received a call from the office because the roofer wanted me back there to inspect the crickets that he says are now installed. When I declined, he asked if I would accept pictures and let him finish roofing.
Look at the garage in the background.
If he knew the code, he could potentially whip me on this one.
R907.1 General. Materials and methods of application used for re-covering or replacing an existing roof covering shall comply with the requirements of Chapter 9.
Exception: Reroofing shall not be required to meet the minimum design slope requirement of one-quarter unit vertical in 12 units horizontal (2-percent slope) in Section R905 for roofs that provide positive roof drainage.
There are enough oddities about the addition to the house and garage that I do believe that they are bootleg.
